Using second drive (ext4) in Linux--tried the tip
I followed these instructions to get my second drive to serve files (Ubuntu 18). When I go to add folder to a library, in the file selector nothing appears under /hdd and manually entering /hdd/Videos does not give me movies in that library.
df shows/dev/sdb1... /hdd
fstab has UUID=2d875975-15c9-4fe0-99d7-7ccf9ef64fa8 /hdd.
Running ls -l at /hdd shows drwxr-xr-x 5 plex plex 4096 Jun 3 09:03 Videos.
What am I doing wrong?
My solution was to
  1. change the username in /etc/default/plexmediaserver [edit: this did nothing, see below]
  2. re-mount (with bind) the Videos folder by itself to a new root folder and
  3. set permissions as in Chuck’s instructions.
(Following the tip by itself did not work.)
I added the following to /etc/fstab
/hdd/Videos /VideoMount none defaults,bind 0 0
This finally allowed me to add libraries at /VideoMount/Movies and /VideoMount/TVShows.
(Strangely, for that last one, TV Shows with a space no longer worked as it did on my earlier machine; I had to eliminate the space.)
I have no idea why this incantation worked and others did not.
As a note to all reading here:
/etc/default/plexmediaserver is for SYSV Init systems only (Ubuntu 14 / Debian 7)
A proper override file must be used for Ubuntu 16+ and Debian 8+ which use systemd
Quotes and \ do work in /etc/fstab when done correctly. It’s tricky so practice before rebooting the system.
  1. You are right. sudo ps -u plex shows that user plex is still running all plex processes.
  2. I did not use any quotes, \, or name-internal spaces in /etc/fstab. Rather, I was trying using the Plex web GUI to set /VideoMount/TV Shows as a library location, and this failed until I renamed the directory to remove the space.
I am guessing that my key fix was to give my videos a mount point dedicated to them by re-mounting (with bind) my /hdd/Videos directory at VideoMount.
Why can’t you just use the exact mount point /hdd/Videos you’ve defined?
PMS will let you drill into /hdd (presuming you set 755 permissions on /hdd AFTER being mounted the first time.
Remember: Set the permission of the mount point AND set the permission of the mounted root dir . (Often overlooked)
I tried that, but never was able to drilldown in the GUI.
…set the permission of the mounted root … 755 permissions on /hdd
I did not do that as I did not want to alter the permissions of all the other non-media files on /hdd (/dev/sdb1).
I did however set permission for the /hdd/Videos directory, using your two find... chmod commands. But I see that that was not enough.
How does “Set the permission of the mount point” differ from “set the permission of the mounted root dir”? I have mounted /dev/sdb1 at the mount point /hdd – isn’t that the same as the “mounted root dir”?
