Using Transcode for "Convert Video While Recording" results in Transcode Errors
Hello,
I cannot use the Transcode option under “Convert Video While Recording” for the DVR settings. If this is set, all recordings fail with “Transcoder error”. I am using the HDHomeRun Connect. PMS 1.10.0.4523 on Windows 10. I have 2 PMS servers. The other is running WHS 2011 and has the same issue (talking to the same HDHomeRun Connect). Recordings do work with this setting set to NONE. But I then have to transcode the .ts files to M4V for playback on Apple TV.
Log extract from the time the recording starts …
Nov 29, 2017 19:00:00.727 [2164] ERROR - Unable to find title for item of type 5
Nov 29, 2017 19:00:01.392 [6064] ERROR - [Transcoder] [h264 @ 05cfb380] SPS unavailable in decode_picture_timing
Nov 29, 2017 19:00:01.393 [5008] ERROR - [Transcoder] [h264 @ 05cfb380] non-existing PPS 0 referenced
Nov 29, 2017 19:00:01.394 [6064] ERROR - [Transcoder] [h264 @ 05cfb380] SPS unavailable in decode_picture_timing
Nov 29, 2017 19:00:01.395 [5008] ERROR - [Transcoder] [h264 @ 05cfb380] non-existing PPS 0 referenced
Nov 29, 2017 19:00:01.400 [7924] ERROR - [Transcoder] [h264 @ 05cfb380] decode_slice_header error
Nov 29, 2017 19:00:01.401 [6064] ERROR - [Transcoder] [h264 @ 05cfb380] no frame!
… (repeats above many times ) …
Nov 29, 2017 19:00:02.312 [5008] ERROR - [Transcoder] [h264 @ 05cfb380] reference picture missing during reorder
Nov 29, 2017 19:00:02.313 [6064] ERROR - [Transcoder] [h264 @ 05cfb380] Missing reference picture, default is 2147483647
Nov 29, 2017 19:00:02.319 [7924] ERROR - [Transcoder] [h264 @ 05cfb380] mmco: unref short failure
Nov 29, 2017 19:00:02.320 [6064] ERROR - [Transcoder] [h264 @ 05cfb380] mmco: unref short failure
Nov 29, 2017 19:00:02.321 [5008] ERROR - [Transcoder] [h264 @ 05cfb380] number of reference frames (0+5) exceeds max (4; probably corrupt input), discarding one
Nov 29, 2017 19:00:02.321 [7924] ERROR - [Transcoder] [h264 @ 05cfb380] reference picture missing during reorder
Nov 29, 2017 19:00:02.322 [6064] ERROR - [Transcoder] [h264 @ 05cfb380] Missing reference picture, default is 65469
Nov 29, 2017 19:00:02.327 [7924] ERROR - [Transcoder] [h264 @ 05cfb380] reference picture missing during reorder
Nov 29, 2017 19:00:02.328 [5008] ERROR - [Transcoder] [h264 @ 05cfb380] reference picture missing during reorder
Nov 29, 2017 19:00:02.328 [6064] ERROR - [Transcoder] [h264 @ 05cfb380] Missing reference picture, default is 2147483647
Nov 29, 2017 19:00:02.329 [7924] ERROR - [Transcoder] [h264 @ 05cfb380] Missing reference picture, default is 2147483647
Nov 29, 2017 19:00:02.343 [6064] ERROR - [Transcoder] [h264 @ 05cfb380] reference picture missing during reorder
Nov 29, 2017 19:00:02.344 [5008] ERROR - [Transcoder] [h264 @ 05cfb380] Missing reference picture, default is 65465
Nov 29, 2017 19:00:02.455 [7924] ERROR - [Transcoder] [h264 @ 05cfb380] mmco: unref short failure
Nov 29, 2017 19:00:02.456 [6064] ERROR - [Transcoder] [h264 @ 05cfb380] mmco: unref short failure
Nov 29, 2017 19:00:08.128 [7924] INFO - CodecManager: obtaining decoder ‘aac_latm’
Nov 29, 2017 19:00:09.689 [2164] ERROR - Unable to find title for item of type 5
Nov 29, 2017 19:00:09.691 [6064] ERROR - [Transcoder] [stream_segment,ssegment @ 05d11a40] sample rate not set
Nov 29, 2017 19:00:09.695 [5008] ERROR - [Transcoder] Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
Nov 29, 2017 19:00:09.703 [7924] ERROR - [Transcoder]
Nov 29, 2017 19:00:09.754 [2164] ERROR - Unable to find title for item of type 5
Nov 29, 2017 19:00:09.936 [5008] ERROR - [Transcoder] http://127.0.0.1:32400/livetv/sessions/a759c5ff-7c90-4162-83a0-5ee909763333/afcc2c5c-a7f8-4f30-bbbf-f2151a497589/index.m3u8?offset=-1.000000&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx: Invalid data found when processing input
