For the past few days all my shows have failed to record.
These are repeating shows that I’ve been recording every day for some time.
Here is what I find in Plex Media Server.log
Dec 07, 2018 18:55:00.820 [0x7f57bfbfe700] ERROR - Unable to find title for item of type 5
Dec 07, 2018 18:55:00.821 [0x7f57bfbfe700] ERROR - Unable to find title for item of type 5
Dec 07, 2018 18:55:01.416 [0x7f57c6fff700] ERROR - [Transcoder] [h264 @ 0x2d1db40] SPS unavailable in decode_picture_timing
Dec 07, 2018 18:55:01.418 [0x7f57ce7fd700] ERROR - [Transcoder] [h264 @ 0x2d1db40] non-existing PPS 0 referenced
Dec 07, 2018 18:55:01.422 [0x7f57c6fff700] ERROR - [Transcoder] [h264 @ 0x2d1db40] SPS unavailable in decode_picture_timing
Dec 07, 2018 18:55:01.424 [0x7f57ce7fd700] ERROR - [Transcoder] [h264 @ 0x2d1db40] non-existing PPS 0 referenced
Dec 07, 2018 18:55:01.427 [0x7f57c6fff700] ERROR - [Transcoder] [h264 @ 0x2d1db40] decode_slice_header error
Dec 07, 2018 18:55:01.429 [0x7f57c6fff700] ERROR - [Transcoder] [h264 @ 0x2d1db40] no frame!
Dec 07, 2018 18:55:01.456 [0x7f57ce7fd700] ERROR - [Transcoder] [h264 @ 0x2d1db40] SPS unavailable in decode_picture_timing
Dec 07, 2018 18:55:01.459 [0x7f57c6fff700] ERROR - [Transcoder] [h264 @ 0x2d1db40] non-existing PPS 0 referenced
Dec 07, 2018 18:55:01.461 [0x7f57ce7fd700] ERROR - [Transcoder] [h264 @ 0x2d1db40] SPS unavailable in decode_picture_timing
Dec 07, 2018 18:55:01.464 [0x7f57c6fff700] ERROR - [Transcoder] [h264 @ 0x2d1db40] non-existing PPS 0 referenced
Dec 07, 2018 18:55:01.466 [0x7f57ce7fd700] ERROR - [Transcoder] [h264 @ 0x2d1db40] decode_slice_header error
Dec 07, 2018 18:55:01.469 [0x7f57c6fff700] ERROR - [Transcoder] [h264 @ 0x2d1db40] no frame!
The channel works fine with every app that can use the HD Homerun.
The HD Homerun log shows that it did started streaming to Plex and stoped after a few seconds
I just purchased plex pass and installed plex on new QNAP NAS and I’m using HD HomeRun Quattro. Everything is working as expected, Live TV is great. However, I set my first show to record this evening and when I just went to play it, a message is there stating “There was a transcode error.” Was not expecting this. I’m new to all this and hoping to kill DirecTV, but this won’t do. Where do I start in trying to fix this?
I’m having the same issue, same messages in Plex Media Server.log.
I found out that this problem occures only with HD channels / recordings. When a recording failed because of the transcode error, I changed it immediately and forced using a SD channel - recording instantly worked.
Might there be anything wrong with transcoder settings in case of HD? Or is it an issue with the tuner?
Would be great if the Plex team could give a hint how to solve this error.
