Varys for Plex app is here!
@blassley: Notifications like Tautulli are not supported, so far you only get notified about new PMS versions. Other notifications you can use the official Plex app currently. OpenVPN/DynDNS is not required, the only thing you need is a port forwarding on your router, see here: https://support.plex.tv/articles/200289506-remote-access/ Varys connects via Plex remote access.
@Kloudz: I’ll keep Varys and Remote for Tautulli separately, but as Plex come with more and more functions from Tautulli built-in, I would expect that at some points it becomes obsolete. I think there’s not too much need for Varys on desktop because here you have everything in the web interface, but you never know^^
Which change to Tautulli do you mean? For Remote for Tautulli you will always need to setup your own server while Varys will always directly connect to your Plex server.
I was talking about Remote for Tautulli.
But OK, I am definitely looking forward to Varys on Desktop. If I have to pay another $2.99 for Vary’s on Desktop, so be it. Always great to support a developer that has a great app.
I have a feature request. On the Vary’s activity page. The thumbnail list, is a bit too big for my taste. I was thinking the same size as the Tautulli App would be great.
I love the Game of Thrones reference by the way. House Stark for me all the way :smiley:
Love Varys, great work! I was more than happy to purchase the app. The only feature I would love to see come from Tautulli is the ability with notifications to have a groupme bot. My family has loved being updated on groupme when new movies are added. It has been pretty slick to have it automatically send the name of the movie and poster and automatically update everyone.
Is multiple server support possible?
If not, feature request! :grinning:
@MediaHorder multiple servers is already possible, if you have added more than one server to your account a server switch option will appear on the activity tab :blush:
That works assuming you are using the same account.
What if you aren’t? :slight_smile:
Tis the main reason I use both Remote for Tautulli and Varys.
Currently only multiple servers in the same account are supported :confused:
It would be awesome if I could use one app for both accounts though. My number 1 feature request. :grin:
@MediaHorder maybe this feature could make it into an upcoming version :face_with_hand_over_mouth:
Would also love support for multiple accounts.
Also is there a way to logout?
Good point. I also don’t notice a way to log out.
Multiple accounts will come later this year, as this needs some heavy testing it takes a bit longer :blush:
Regarding logout: that’s right there’s currently no way to log out, just remove the app to do so. The version with multiple accounts will have an option to remove accounts :+1:
Currently I’m working on the next big update for Varys for Plex. While doing this I came across some questions regarding Plex server usage that are important to develop some features.
I’ve created a very small 4 questions survey (should not take longer than 2 minutes) that I would ask you to answer. This would help me a lot! The survey can be answered by every Plex admin, no need to have Varys.
Many thanks in advance!! :sunglasses::nerd_face:
Link to the survey: https://www.varys-app.com/survey
Just an FYI. If you change your plex password, Varys can no longer connect and gets stuck in a loop, repeating the same error message “Failed to establish a connection to Plex” ad infinitum with a ‘Retry’ prompt. There’s no way to cancel or break out to get back into the configuration to change settings. Liking the app and relaunching doesn’t help.
I know I can remove /re-add the app but that’s a bit clumsy.
@SpinCharm yeah that’s a known issue. The next version will come with multiuser support, there you have an option to remove accounts without deleting the app :sunglasses:
Can you port Varys to macOS with Catalyst?
@grogster thanks for the awesome update.
Would love to see a combined view for multi server support.
Also it’s seemingly connecting via HTTP vs HTTPS, any way to force HTTPS?
@MediaHorder latest version comes with a combined view for multi server support :wink:
Please use version 1.7.1 only as 1.7.0 contains a major issue! (sorry for that)
Connection handling should use HTTP only for local connections (using HTTPS for local connections will not work - the HTTPS certificate will be recognized as invalid as it only includes the *.plex.direct hostname, not your local IP address), if you’re accessing your server using Plex remote access it should use HTTPS (if you didn’t setup your server to forced use HTTP). In the end Varys asks Plex for all known connections and uses the fastest one, using the protocol given by Plex.
If you want to check it by yourself get a Plex token (how to) and call https://plex.tv/api/resources?includeHttps=1&includeRelay=1&X-Plex-Token=INSERT-TOKEN-HERE. For remote connections the “uri” field of the connection will be used.
Thanks for this.
I use my own certificates but routed on port 443. (Remote server)
I would like it to communicate securely over 443 and never via 80 but I can’t turn it off in plex for other reasons… I’d prefer it to be secure rather than HTTP.
Anyway to force Varys to always use 443?
Using multiple servers by the way.
Have you checked what the api call returns? Varys prefers HTTPS already.
