VC1 Transcoding Broken [Again]
Server Version#: 1.42.2.10156
Player Version#: 4.157.0
Following up from a post I made in 2024. VC1 transcoding is broken again in the same fashion as below. It stalls without playing on some TV apps and the web player alike. That said, the actual app for Windows and Android does work appropriately. A bug fix was previously made that addressed the issue. I am unaware how long this has been occurring since the fix.
I did attempt rollback to 1.42.1.10054 without difference.
Logs provided replicating the issue as below. I did remove the installer and plugin files due to size constraints.
Plex Media Server Logs_2026-01-04_19-56-05 (2).zip (2.8 MB)
Thank you to anyone who can help.
Update. It appears updating to the current 1.43 beta seems to have solved the issue? Take that as you will
