Verarbeitung läuft. Bitte warten
Yes, yesterday i did a restart of the Synology.
HDD have enough space.
Don´t know why i doesn´t work.
I need to see what is happening with the Package Center.
Please create the scheduled task – type ‘user script’.
It looks like this . ( use your email )
  1. user - root
  2. commands to execute
cat /var/log/synopkg.log
df -h
Save (OK) this task then run it 1 time.
It will send results to your email.
Please share that email contents (the package center log)
I followed your instructions but didn’t get an email.
Did you mean this one:
Synology Log.txt (832.7 KB)
It should be this one @ChuckPa
Synology.txt (832.8 KB)
Thank you for the logs.
I see where things were.
At this point, I think you were actually getting the upgrade and it was taking time to complete.
This action sequence shows me you uninstalled 1.21.0.3744 (which is from Package Center)
2022/06/10 16:32:40 uninstall PlexMediaServer: begin to stop version 1.21.0-3744
2022/06/10 16:32:40 uninstall PlexMediaServer 1.21.0-3744 Begin start-stop-status stop
2022/06/10 16:32:41 uninstall PlexMediaServer 1.21.0-3744 End start-stop-status stop ret=[0]
2022/06/10 16:32:43 uninstall PlexMediaServer: stop version 1.21.0-3744 successfully, result 0
2022/06/10 16:32:43 uninstall PlexMediaServer 1.21.0-3744 Begin preuninst
2022/06/10 16:32:43 uninstall PlexMediaServer 1.21.0-3744 End preuninst ret=[0]
2022/06/10 16:32:43 Release systemd-unit for PlexMediaServer when 0x0004 (ready)
2022/06/10 16:32:43 Release systemd-unit for PlexMediaServer when 0x0004 (done)
2022/06/10 16:32:43 uninstall PlexMediaServer 1.21.0-3744 Begin /bin/rm -rf /volume1/@appstore/PlexMediaServer
2022/06/10 16:32:44 uninstall PlexMediaServer 1.21.0-3744 End /bin/rm -rf /volume1/@appstore/PlexMediaServer ret=[0]
2022/06/10 16:32:44 uninstall PlexMediaServer 1.21.0-3744 Begin /bin/rm -rf /volume1/@apptemp/PlexMediaServer
2022/06/10 16:32:44 uninstall PlexMediaServer 1.21.0-3744 End /bin/rm -rf /volume1/@apptemp/PlexMediaServer ret=[0]
2022/06/10 16:32:44 Release video-driver for PlexMediaServer when 0x0004 (ready)
2022/06/10 16:32:44 Release video-driver for PlexMediaServer when 0x0004 (done)
2022/06/10 16:32:44 uninstall PlexMediaServer 1.21.0-3744 Begin postuninst
2022/06/10 16:32:44 uninstall PlexMediaServer 1.21.0-3744 End postuninst ret=[0]
2022/06/10 16:32:45 uninstall PlexMediaServer: Uninstall 1.21.0-3744 successfully
2022/06/11 08:49:04 (system) trigger DhcpServer 1.0.1-0036 Begin start-stop-status stop
2022/06/11 08:49:04 (system) trigger MediaServer 2.0.2-3053 Begin start-stop-status stop
It is VERY likely that DSM had found your old, hidden, data area and was trying to move it to “PlexMediaServer”
We can check for that.
Are you able to SSH (Putty will also work) to get into the command line of the NAS?
Thanks!
Unfortunately, I’m not familiar with Putty and SSH.
But i can try to download Putty, and let´s see…
Do you have Teamviewer ?
i have download it.
I am online.
Can you PM me, regarding the code…
