Video blank but audio playing
Video is showing as black, but audio is played.
Client
AppleTV HD
tvOS 13.2 (17K82)
Plex vs 2.11 (13805)
GigE connection
Server
Synology DS1019+
PMS 1.18.2.2029-36236cc4c
GigE connection
Media:
File 1 - MP4 container
As listed in server activity:
Video: 480p (HEVC Main 10) - Direct Play
Audio: AC3 5.1 - Direct Play
Technical Details on AppleTV
Source: Direct Play
Quality: 1920x1080 @ 5.9 Mbps
Video: HEVC
Audio: AC3
Player: AVPlayer
FIle2 - MP4 container
Video: 1080p (HEVC Main 10) - Direct Play
Source: Direct Play
Video: HEVC
Audio: AC3
Player: AVPlayer
As a test, I tried another file, which works successfully:
File 3 - MKV container
Video: 1080p (HEVC Main 10) - Direct Stream
Audio: English (AAC 5.1) - AC3 - Transcode
Source: Transcode
Video: Copy (HEVC)
Audio: Transcode (AAC - AC3)
Player: AVPlayer
Transcode Reason: App cannot direct play this item. No direct play video profile exists for protocol http, with container mkv, and video codec havoc.
Note same video codec and it works.
If there’s other info I should be including in bug reports please let me know.
Side Note/Possible unrelated issue:
After trying to play a second time to get the technical details , AppleTV is just showing spinning wheel. Force quit plex client on AppleTV, and looking in the logs see the following:
Nov 18, 2019 08:32:29.472 [0x7f53ea72c700] DEBUG - Failed to stream media, client probably disconnected after 294912 bytes: 32 - Broken pipe
Before I could get Xcode connected to look at AppleTV logs, it started working again after about 10 minutes.
I reproduced the problem and captured the logs from the appleTV plex process. If they are of any use, let me know and we can figure out how to transmit them (they include PII, so don’t want to attach them.)
