I have a problem with some Video files. It seems like the sound is fine and running flawless, but the video stream seems to lag or better repeating the same frames every seconds.
My first idea was that the media format is simply not supported by the ATV, maybe a variable bitrate. But should not the server then rather re-encode the stream?
<span style="color:#000000;">Medien</span>
- Video Resolution 720p
- Spielzeit 53:07
- Bitrate 3338 kbps
- Width 1280
- Height 720
- Aspect Ratio 1.78
- Container MKV
- Video Frame Rate PAL
<span style="color:#000000;">Teil</span>
- Spielzeit 53:07
- File tvp-theknick-s01e01-720p.mkv
- Size 1.24 GB
- Container MKV
<span style="color:#000000;">Video</span>
- Codec H264
- Bitrate 2695 kbps
- Bit Depth 8
- CABAC 1
- Chroma Subsampling 4:2:0
- Color Space yuv
- Spielzeit 53:07
- Frame Rate 25.000 fps
- Frame Rate Mode cfr
- Has Scaling Matrix 0
- Height 720
- Level 4.1
- Profile high
- Ref Frames 5
- Scan Type progressive
- Width 1280
<span style="color:#000000;">Ton</span>
- Codec AC3
- Kanäle Stereo
- Bitrate 192 kbps
- Sprache Deutsch
- Bit Depth 16
- Bitrate Mode CBR
- Dialog Norm -31 dB
- Spielzeit 53:07
- Sampling Rate 48000 Hz
- Codec AC3
- Kanäle 5.1
- Bitrate 384 kbps
- Sprache English
- Bit Depth 16
- Bitrate Mode CBR
- Spielzeit 53:07
