Video Preview Thumbnails not created with mpg files?
PMS: 1.13.8.5395 on macOS 10.13.6
Clients: Plex Web App 3.71.1 & Roku 5.3.10
I have a library of recorded television with the “Enable video preview thumbnails” option enabled. I noticed the other day that the feature is no longer working. As in, when I play an episode and fast forward, no video preview thumbnails are shown. And I know that they were working for this particular show before. So I did some digging and here’s what I’ve come up with:
If I watch Season 2, Episode 1 of The Good Place, I get video preview thumbnails (with either client mentioned above). It was recorded using the Plex DVR/Live TV function and is a .mkv file.
If I watch Season 3, Episode 1 of The Good Place, I do not get video preview thumbnails (with either client mentioned above). It was recorded using the Channels DVR and is a .mpg file.
I’ve attached the xml files from both episodes below:
TGP S02E01.txt (3.0 KB)
TGP S03E01.txt (3.1 KB)
Does Plex not support video preview thumbnails with .mpg files?
P.S. Both files are in a Plex only accessible directory. I move them out of the Channels DVR directory on another computer and move to my main Plex server.
Both files play perfectly.
I have also noticed this on the series Lethal Weapon with episodes recorded with Plex vs. Channels.
I also have both the “Generate video preview thumbnails” and “Generate chapter thumbnails” setting set to “as a scheduled task and when media is added” on this Plex server.
2018-10-07 Additional Information - After seeing some other posts with similar problems I thought about the fact that I haven’t added any other type of files to my library since I’ve noticed this problem. So it may not be related to file type but version of the Plex Server.
This problem is still happening under:
PMS: 1.13.9.5439
Clients: Roku Plex Preview 6.0.16.5108-f6fd07da6-PlexPreview & PMP for Mac 2.20.0.909-46413dd1
Added S03E03 of the Good Place, watched the Activity Monitor while it built the Video Preview Thumbnails and the problem still exists.
