Video Skips forward
I just installed PlexConnect last night on my Apple TV 3 and it works pretty great for the most part, but videos have the tendency to jump forward 15 or 30 seconds every so often. Here's the pertinent system info:
Apple TV 3 running 5.3
DNS Set to 10.0.1.15
PlexConnect installed on Newest Mac Mini Running OS X 10.9 (Mavericks DP7) 2.3GHz Quad-Core i7, 16GB RAM
Local IP address for PlexConnect 10.0.1.15
PMS is installed on same machine (Mac Mini with OS X 10.9, etc.)
PMS version 0.9.7.28
PMS on 10.0.1.15
PlexConnect GIT source downloaded Sept 7, 2013. Main download, not a testing branch.
Settings.cfg: http://pastebin.com/Psffc6WH
Video Info: http://pastebin.com/tim0a8LQ
http://pastebin.com/ngH9S06T
and http://pastebin.com/aWARdjj4
Plexconnect.log: http://pastebin.com/M4U5Cc1Y (I can't do the more detailed log at the moment, but I can post it later if needed).
When the video jumps forward, sometimes rewinding will allow the spot to play through with no issues, but sometimes it jumps forward again at the same spot. I have had this happen both ways on the same file, at the same point.
Any Ideas?
Anyone?
I'm having the same problem, can anyone help?
With me, it turned out to be a batch of badly-made files. If you're getting the experience with a wide variety of files, I'd go ahead and start a fresh thread and post all your info so the folks here can have a good set of data to help you.
@jedibugs thanks for the update and helpful info.
@jakesim111 noone is going to be able to know if you have the same problem without any information, please read the "READ BEFORE POSTING" sticky if you need some help and create a new thread.
Hey guys, I found that it was because my OS Hdd was full, once i cleared unnecessary files it worked fine.
