Videos with 7.1 DTS-HD-MA do not start or get transcoded (despite hardware support)
Hi, they looked into this issue, will be fixed in the next beta
when that is out - retest it using the original movies you had a issue with, and the 1st sample and let me know if its still a problem.
if its still a problem add new logs
Wow. I definitely appreciate that. Thank you
@dan-the-man
It seems to be fixed. Currently no more issues. No more transcoding… perfect! Videos start in an appropriate way! I’m going to do further testing this evening on my second device.
I will post a final report later.
Okay! Additional testing confirms it has been fixed, from my point of view. Would someone else like to confirm my tests?
Otherwise @dan-the-man should I press the ā€œSolutionā€-Button? (What would happen if the issue re-arises?)
can if you like. reopen the thread if exact same issue
Hi @dan-the-man
I started and created my own thread. How should I continue or what should I test?
thx
greets
KCX
