Voice control of Plex App on FIRE TV 4K
I found this on YouTube.
(1476) Trying to control Plex with Alexa on Fire Stick 4K - YouTube
I had to laugh, because this is pretty much where I am at trying to control my Plex Server via my FIRE TV 4K.
Questions:
  1. Is this really as good as it gets?
  2. My FIRE TV keeps telling me to set up Plex on my phone. Why?
  3. If I buy the Plex Pass Lifetime, will anything change with voice commands on FIRE TV?
  4. Can I create a Playlist that I can activate with voice commands to play a specific video? (I tried, but Alexa said “not supported”.)
Background: I have my Plex Server running, and I can access it from my FIRE TV. Movies play fine if I manually select them with the remote. (And sitting 18" away from my 55" TV/monitor I can kinda do it. I’m legally blind. That’s the reason I started down this road. So I could watch exercise videos without asking my wife to turn everthing on, find the disk, find the remote, and use those tiny buttons to select and play/pause the videos.)
Has anyone used a Plex Player on an Amazon FIRE TV? OR with an Echo dot? Or with the Alexa app on an iPhone? I understand that their are “Skills” for Plex. Might they do better?
Is there another device that works well with voice commands?
All input appreciated.
That is what Plex for Alexa is, a skill which you need to enable and link to your plex account and your server needs remote access enabled Amazon.com: Plex : Alexa Skills
probably just to sign in or it is telling you to set up alexa but without knowing exact message and when it is appearing hard to say
No
I don’t understand why you would make a playlist to play a specific video. Just play the video. You can tell it to play a specific playlist or tell it play a specific movie etc. Info on the commands Alexa supports can be found here https://support.plex.tv/articles/236324808-alexa-voice-commands/
Hours later, I still can’t get Alexa to work with the Plex app on FIRE TV 4k.
I checked my Plex Server and it says it is available both privately and publically.
I have gone to the Alexa Web app and enabled the Alexa Skills for Plex.
I can say “Open Keith’s Plex” and the Fire TV 4k opens my server. I can browse my libraries with the remote cursor arrows. I can open a movie and play it.
If I ask Alexa “ask plex to play the same movie I just watched>” I am told “This is what I found…” and it isn’t the video on my Plex server. Rather, Alexa wants me to rent the movie…
Ditto if I just say “play ”.
I have changed my Plex account password, reinstalled the Plex app on the FIRE TV 4k, and un-enabled / reenabled the Alexa Skill for Plex.
This is the guide I found on the web
How To Use Plex with the Amazon Echo - Tech Junkie
I am at a loss on how to continue.
I am sure I am missing something really simple, But I can’t seem to find what it is.
Guidence appreciated.
I’m not really clear which Alexa device you are using. Are you using an Echo or talking in the Fire TV remote?
I am using the FIRE TV 4k remote. I press the mic button and speak commands.
When I “ask plex to connect to Keiths Plex” I am told that I only have one server in my Plex account and that Keiths Plex is automatically connected.
If I say “open Keiths Plex” I am told OK.
If I “ask Plex to play Jeff Beck at Ronnie Scotts”, I am told that I do not have any media in my server. I am asked if I want to setup the Plex Video Player. I say “yes”. I am told there are no players on my network (?) and that a card has been placed in my Alexa app to help me out. (or something like that. I am swapping between HDMI ports between my FIRE stick and my computer…)
So if I use the FIRE remote keypad, I can select movies on my Plex server (Keiths Plex). I can play the movies. The issue does not appear to be my Plex server, but Alexa not being able to query what I have on my server(?).
I have my server configured for public access. I have enabled the manual port option as well. No difference.
I’ll be back to it tomorrow. I really want to get this working…
(And then I get to do it all over again with a NVDA Shield Pro. Happy days!)
Thanks for your ideas on how to debug this.
Another YouTube with similar results to what I am seeing…
(1476) Amazon Fire TV Cube Plex Voice Control Grrrrrrrrrrrrrrrrrrrrrrrrrr - YouTube
Maybe I need to give up on the FIRE TV 4k remote and move on to an Echo dot with Alexa Skills…
I found this on the web
Alexa and Fire TV Stick 4k Max : r/PleX (reddit.com)
This seems to make sense. Plex works great if steered by the remote buttons. But Alexa Skills does not know about the Plex app on my Fire TV 4k.
I just uninstalled, re-downloaded, and linked the Plex app on my FRV4k. I re-enabled the Alexa Skills (and hence logged in to the Plex site using new credentials).
It still doesn’t work.
Is there a beta Plex app that I can install directly on my FTV4K?
This is posted on the Pex site
Release Announcements - Android TV beta - Plex Players / Player Betas - Plex Forum
Plex for Android 9.26.0.2526-beta
The version I downloaded today from the Amazon Store is
9.25.0.2374
So this is consistent with the redit post I previously referenced.
I need to purchase a Plex Pass to download the beta. (But I was planning on that anyway once I had proof of concept…)
Wish me luck!
;u
I am now running Fire Tv 4k Plex app version 9.26.0.2526-beta
Alexa still doesn’t think I have any Plex players on my network.
Do Plex software developers monitor this forum? Do I need to contact Plex support via another method?
