I tried to do this with the Android Plex companion on my PlexMediaPlayer which is installed on a PC. I have enabled CEC rebooted and there is no volume control.
Is this functioning?
Simple question. Does someone have an answer?
have you set your player to transcode all audio? otherwise, the server it sending bit-perfect bitstream audio and can’t make any changes, volume included. It would be like asking your DVD/BR player to change the DVD player’s volume output… there really isn’t such a thing…
Hi
Hmmm, I don’t think that this is relevant to CEC. CEC would be doing a control signal to the receiver to adjust it’s volume in the same way as a TV can control the volume using CEC.
However, it appears that the issue may be that the nVidia GTX960 that I am using doesn’t actually support CEC. I have ordered a Pulse-Eight CEC USB adapter that provides such a signal. We will see.
Makes sense- I hadn’t focused on the CEC part of the question, just on the volume control.
Thanks for shifting the focus back, and sorry to not have been of more help!
If everyone would at least try to help as you did this forum would be far better. Most questions never get answered.
We should all ask out questions on the GIT hub and perhaps the pressure would get some support from Plex around here.
