I do not use it and would prefer to just show “On Deck”.
You can disable BOTH in Advanced. But that is NOT what I want.
Can we get some more control of what we display please?
Note screenshot. “Up Next” is lumped in with the other choices (including “On Deck”)
I aksed this back in 2018 and not fixed. Not sure why there cannot be a bit more granularity? I am sure there are others that want the opossite of what I want. Or want both or neither.
If I understand correctly what you’re asking, you can. While on the Home screen, click the edit (pencil) icon toward the top-right. This will allow you to configure what is shown there. You can then reorder or remove existing items, or reset it to its defaults:
