Hello, since last beta I ave a strange problem. The movies the remote users see, are added to my watched movies. They are users with their own Plex account, nothing to do with mine. Before it was working fine. Anyone else having the same issue? How can I solve it?
Are you using the trakt.tv plugin?
If so, you must create a filter in its preferences.
https://github.com/trakt/Plex-Trakt-Scrobbler/wiki/FAQ---Scrobbling#2-why-are-videos-watched-by-other-users-being-scrobbled-to-my-profile
Yes I am using tract.tv. But I am using it the last year without this issue. why now?
I cannot tell you. Speculation: probably the plugin didn’t work fully before. (It does not only scrobble your playbacks to the trakt.tv website, but ‘syncs’ them back into your plex server as well.)
If you did not create a filter in there, then this is the cause. Because it then not only scrobbled your own playbacks but those of your sharees as well - which were then subsequently synced back into your plex account.
Ok thanks. I followed the above instructions and I hope that everything will be ok. Thanks again for your help OttoKerner
