Way to Disable Post-Play Screen?
Is there a way to disable the Post-Play screen after a movie finishes? I prefer to watch the end credits of movies so I don’t like that it puts them in “picture-in-picture”. I also don’t find the recommendations useful, as I generally watch one movie and then move on to something totally different. My desired behavior is for the movie (or episode of a show) to play to completion in fulls screen mode and then I am returned to the last Plex screen I was using (the home screen or the page for that movie, etc.)
Here’s a screenshot of the screen I’m referring to. I’m not sure if Post-Play is the correct term. In this example, it kicked off too early for some reason.
Server Version#: 4.87.2
No, there is not a way to disable the post-play screen.
Cannot as mentioned above but disable credit detection for library ( in library’s advanced settings ) and it will not shrink to post play at final credit marker.
If credit detections got a particular movies marker wrong you can disable it for individual movies.
