Have installed the 22nd’s release and not the same error just can not find the url interface
Chuck. I have just caught up on things, There was a new Server update which I have installed 1.26, and Qnap is up to date. It still does not work so Is it possible to get some help in what ever tinkering is needed to fix things at my end?
here is the recent log from today as I tried to load things.
it ended like this…
Apr 22, 2022 06:11:29.227 [0x7f3b90e640c8] INFO - [CERT/OCSP] Loaded a stale response from cache.
Apr 22, 2022 06:11:29.227 [0x7f3b90e640c8] INFO - [CERT/OCSP] Couldn’t install the cached response; fetching from network.
Apr 22, 2022 06:11:29.227 [0x7f3b90e640c8] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Apr 22, 2022 06:11:29.227 [0x7f3b90e640c8] ERROR - HttpServer: Error binding acceptor: Address in use
Apr 22, 2022 06:11:29.227 [0x7f3b90e640c8] ERROR - HttpServer: Error opening acceptor on IPv6, falling back to IPv4: Address in use
Apr 22, 2022 06:11:29.227 [0x7f3b8c848b38] DEBUG - [CERT/OCSP] HTTP requesting GET http://r3.o.lencr.org/MFMwUTBPME0wSzAJBgUrDgMCGgUABBRI2smg%2ByvTLU%2Fw3mjS9We3NfmzxAQUFC6zF7dYVsuuUAlA5h%2BvnYsUwsYCEgT3Z6aS%2BcrMYjhVFiV4tF3KOw%3D%3D
Apr 22, 2022 06:11:29.248 [0x7f3b90e640c8] ERROR - Error: Unable to set up server: listen: Address in use (N5boost10wrapexceptINS_6system12system_errorEEE)
Above indicates that something is already using port 32400
Have you tried to restart your QNAP?
