hakom
September 23, 2013, 6:08pm
1
Hi everyone,
I cant connect to the trailer page, here is my PlexConnect logfile:
20:03:58 PlexConnect: started: 20:03:58
20:03:58 PlexConnect: IP_self: 192.168.0.12
20:03:58 DNSServer: started: 20:03:58
20:03:58 DNSServer: ***
20:03:58 DNSServer: DNSServer: Serving DNS on port 53.
20:03:58 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.0.12
20:03:58 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
20:03:58 DNSServer: forward other to higher level DNS: 8.8.8.8
20:03:58 WebServer: started: 20:03:58
20:03:59 WebServer: ***
20:03:59 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
20:03:59 PlexGDM: ***
20:03:59 PlexGDM: looking up Plex Media Server
20:03:59 WebServer: started: 20:03:59
20:03:59 WebServer: Failed to access certificate: C:\Users\pascal\Downloads\PlexConnect-masterPlex\./assets/certificates/ = 8.8.8.8
loglevel = Normal
20:03:59 PlexConnect: WebServer_SSL not alive. Shutting down.
20:03:59 PlexConnect: Shutting down.
20:04:00 PlexGDM: servers discovered: 1
20:04:00 XMLConverter: PlexGDM - PMS: 192.168.0.12:32400
20:04:00 WebServer: Shutting down.
20:04:03 DNSServer: Shutting down.
20:04:03 PlexConnect: shutdown
and if i replace normal with High i got this logfile..
20:06:59 PlexConnect: started: 20:06:59
20:06:59 Settings: getsetting enable_plexconnect_autodetect=True
20:06:59 PlexConnect: IP_self: 192.168.0.12
20:06:59 Settings: getsetting enable_dnsserver=True
20:06:59 DNSServer: started: 20:06:59
20:06:59 Settings: getsetting port_dnsserver=53
20:06:59 Settings: getsetting ip_dnsmaster=8.8.8.8
20:06:59 Settings: getsetting prevent_atv_update=True
20:06:59 DNSServer: ***
20:06:59 DNSServer: DNSServer: Serving DNS on port 53.
20:06:59 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.0.12
20:06:59 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
20:06:59 DNSServer: forward other to higher level DNS: 8.8.8.8
20:06:59 WebServer: started: 20:06:59
20:06:59 Settings: getsetting ip_webserver=0.0.0.0
20:06:59 Settings: getsetting enable_webserver_ssl=True
20:06:59 Settings: getsetting port_webserver=80
20:06:59 WebServer: ***
20:06:59 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
20:06:59 ATVSettings: init class CATVSettings
20:06:59 ATVSettings: load settings
20:06:59 Settings: getsetting enable_plexgdm=True
20:06:59 PlexGDM: ***
20:06:59 PlexGDM: looking up Plex Media Server
20:06:59 PlexGDM: Sending discovery message: M-SEARCH * HTTP/1.0
20:06:59 PlexGDM: Received data from ('192.168.0.12', 32414)
20:06:59 PlexGDM: Data received:
HTTP/1.0 200 OK
Content-Type: plex/media-server
Resource-Identifier: [code appears here, but due to safety issue I deleted it]
Port: 32400
Updated-At: 1379958144
Version: 0.9.7.28-f80a4a2
20:06:59 Settings: getsetting port_ssl=443
20:06:59 Settings: getsetting certfile=C:\Users\pascal\Downloads\PlexConnect-master\assets\certificates railers.pem = 8.8.8.8
20:06:59 WebServer: Failed to access certificate: C:\Users\pascal\Downloads\PlexConnect-master\assets\certificates railers.pem = 8.8.8.8
20:07:00 PlexGDM: servers discovered: 1
20:07:00 PlexGDM: pascal-PC 192.168.0.12:32400
20:07:00 XMLConverter: PlexGDM - PMS: 192.168.0.12:32400
20:07:00 ATVSettings: setOption: update pms_uuid to ('code ',)
20:07:33 PlexConnect: Shutting down.
20:07:33 WebServer: Shutting down.
20:07:33 ATVSettings: save settings
20:07:34 DNSServer: Shutting down.
20:07:34 PlexConnect: shutdown
I installed the certificate and I also have to latest PlexConnect "software"
roidy
September 23, 2013, 6:13pm
2
Your cert path is wrong, why has it got = 8.8.8.8 on the end????
Please post your Settings.cfg file.
hakom
September 23, 2013, 6:24pm
3
here is the seetings.cfg file:
[PlexConnect]
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
certfile = C:\Users\pascal\Downloads\PlexConnect-master\assets\certificates railers.pem = 8.8.8.8
loglevel = Normalenable_dnsserver = True
logpath = .
ip_pms = 192.168.178.10
enable_plexgdm = True
port_ssl = 443
enable_webserver_ssl = True
ip_webserver = 0.0.0.0
prevent_atv_update = True
port_dnsserver = 53
enable_plexconnect_autodetect = True
ip_dnsmaster = 8.8.8.8
may be I have changed too much, since I tried a lot!
roidy
September 23, 2013, 6:28pm
4
Yep, it's screwed up :)
On the certfile line delete the = 8.8.8.8 from the end of the line.
On the next line loglevel there should be a "return" after Normal so that enable_dnsserver is on it's own line.
Personally I would just delete the Setting.cfg file and rerun PlexConnect to generate a fresh one.
hakom
September 23, 2013, 6:37pm
5
Okay thank you! so I just deleted the settings.cfg file, here is the output of plexconnect:
20:36:10 PlexConnect: started: 20:36:10
20:36:10 PlexConnect: IP_self: 192.168.0.12
20:36:10 DNSServer: started: 20:36:10
20:36:10 DNSServer: ***
20:36:10 DNSServer: DNSServer: Serving DNS on port 53.
20:36:10 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.0.12
20:36:10 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
20:36:10 DNSServer: forward other to higher level DNS: 8.8.8.8
20:36:10 WebServer: started: 20:36:10
20:36:10 WebServer: ***
20:36:10 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
20:36:10 PlexGDM: ***
20:36:10 PlexGDM: looking up Plex Media Server
20:36:10 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
20:36:11 PlexGDM: servers discovered: 1
20:36:11 XMLConverter: PlexGDM - PMS: 192.168.0.12:32400
20:37:02 PlexConnect: Shutting down.
20:37:03 WebServer: Shutting down.
20:37:05 DNSServer: Shutting down.
20:37:05 PlexConnect: shutdown
and the new settings.cfg file:
[PlexConnect]
port_pms = 32400
port_webserver = 80
certfile = ./assets/certificates/trailers.pem
loglevel = Normal
logpath = .
port_ssl = 443
port_dnsserver = 53
roidy
September 23, 2013, 6:45pm
6
So is everything working ok now?
hakom
September 23, 2013, 6:53pm
7
Nay the device still tries to connect to the real trailer page, but nothing will be loaded (even after some minutes), but if I try to connect to youtube or itunes festival i will connect promptly to it
roidy
September 23, 2013, 6:56pm
8
Ok, edit Setting.cfg and change:-
loglevel = Normal
to
loglevel = High
Delete the PlexConnect.log file
Run PlexConnect again and try to access trailers on the atv, then shutdown PlexConnect and post the PlexConnect.log file to pastebin.com for me to take a look at.
hakom
September 23, 2013, 6:59pm
9
20:59:45 PlexConnect: started: 20:59:45
20:59:45 Settings: getsetting enable_plexconnect_autodetect=True
20:59:45 PlexConnect: IP_self: 192.168.0.12
20:59:45 Settings: getsetting enable_dnsserver=True
20:59:45 DNSServer: started: 20:59:45
20:59:45 Settings: getsetting port_dnsserver=53
20:59:45 Settings: getsetting ip_dnsmaster=8.8.8.8
20:59:45 Settings: getsetting prevent_atv_update=True
20:59:45 DNSServer: ***
20:59:45 DNSServer: DNSServer: Serving DNS on port 53.
20:59:45 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.0.12
20:59:45 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
20:59:45 DNSServer: forward other to higher level DNS: 8.8.8.8
20:59:45 WebServer: started: 20:59:45
20:59:45 Settings: getsetting ip_webserver=0.0.0.0
20:59:45 Settings: getsetting port_webserver=80
20:59:45 Settings: getsetting enable_webserver_ssl=True
20:59:45 WebServer: ***
20:59:45 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
20:59:45 ATVSettings: init class CATVSettings
20:59:45 ATVSettings: load settings
20:59:45 Settings: getsetting enable_plexgdm=True
20:59:45 PlexGDM: ***
20:59:45 PlexGDM: looking up Plex Media Server
20:59:45 PlexGDM: Sending discovery message: M-SEARCH * HTTP/1.0
20:59:45 PlexGDM: Received data from ('192.168.0.12', 32414)
20:59:45 PlexGDM: Data received:
HTTP/1.0 200 OK
Resource-Identifier: [code ]
Port: 32400
20:59:45 Settings: getsetting port_ssl=443
20:59:45 Settings: getsetting certfile=./assets/certificates/trailers.pem
20:59:45 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
20:59:46 PlexGDM: servers discovered: 1
20:59:46 PlexGDM: pascal-PC 192.168.0.12:32400
20:59:46 XMLConverter: PlexGDM - PMS: 192.168.0.12:32400
20:59:46 ATVSettings: setOption: update pms_uuid to ('code ',)
21:00:19 PlexConnect: Shutting down.
21:00:20 WebServer: Shutting down.
21:00:20 ATVSettings: save settings
21:00:20 DNSServer: Shutting down.
21:00:20 PlexConnect: shutdown
roidy
September 23, 2013, 7:23pm
10
That log show no communication between PlexConnect and the ATV. My first guess would be that the certificate is either not installed on the atv or is installed incorrectly. Could you create the certificate again and reinstall it on the atv.
baa
September 23, 2013, 8:21pm
11
It also doesn't show any DNS request coming in...
Did you switch the aTV DNS setting to your host's IP?
hakom
September 24, 2013, 6:37am
12
alright I will reinstall the certificate (later since I have to work now)…
@ baa: no, the DNS should be choosen automatically
baa
September 24, 2013, 6:54am
13
No, it can't. To use PlexConnect you have to override the aTV DNS setting to point to your PlexConnect machine...
hakom
September 24, 2013, 7:20pm
14
which DNS I have to use? sorry I'm confused :S
baa
September 24, 2013, 7:36pm
15
DNSServer in PlexConnect.
hakom
September 24, 2013, 8:36pm
16
Thank you very much, I really appreciate that both of you had spent some time and successfully solved the issue
