What am I doing wrong here? Any help would be greatly appreciated.
kenneths-MacBook-Air:PlexConnect-master kennethdorman$ sudo ./PlexConnect.py
Password:
10:59:37 PlexConnect: ***
10:59:37 PlexConnect: PlexConnect
10:59:37 PlexConnect: Press CTRL-C to shut down.
10:59:37 Settings: add section PlexConnect
10:59:37 Settings: add option enable_webserver_ssl=True
10:59:37 Settings: add option logpath=.
10:59:37 Settings: add option enable_dnsserver=True
10:59:37 Settings: add option prevent_atv_update=True
10:59:37 Settings: add option port_dnsserver=53
10:59:37 Settings: add option enable_plexconnect_autodetect=True
10:59:37 Settings: add option port_pms=32400
10:59:37 Settings: add option port_webserver=80
10:59:37 Settings: add option ip_plexconnect=0.0.0.0
10:59:37 Settings: add option certfile=./assets/certificates/trailers.pem
10:59:37 Settings: add option ip_dnsmaster=8.8.8.8
10:59:37 Settings: add option loglevel=Normal
10:59:37 Settings: add option ip_pms=192.168.178.10
10:59:37 Settings: add option enable_plexgdm=True
10:59:37 Settings: add option port_ssl=443
10:59:37 PlexConnect: started: 10:59:37
10:59:37 PlexConnect: IP_self: 192.168.1.12
10:59:37 DNSServer: started: 10:59:37
10:59:37 DNSServer: ***
10:59:37 DNSServer: DNSServer: Serving DNS on 192.168.1.12 port 53.
10:59:37 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.1.12
10:59:37 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
10:59:37 DNSServer: forward other to higher level DNS: 8.8.8.8
10:59:38 WebServer: started: 10:59:38
10:59:38 WebServer: ***
10:59:38 WebServer: WebServer: Serving HTTP on 192.168.1.12 port 80.
10:59:38 WebServer: Failed to access certificate: /Users/kennethdorman/Documents/PlexConnect-master/./assets/certificates/trailers.pem
10:59:38 PlexConnect: WebServer_SSL not alive. Shutting down.
10:59:38 PlexConnect: Shutting down.
10:59:39 WebServer: Shutting down.
10:59:42 DNSServer: Shutting down.
10:59:42 PlexConnect: shutdown
