Weird color square in the upper right corner ?
What the heck is this ?
and how do i kill it ?
it shows itself sometimes when "buffering" and sometimes not...
It also shows in the menu now :(
I just want it gone !
You aren't getting enough power to the Pi, you either need a better power adapter or a better USB cable (yes, cheap cables can cause bad power too).
What the hell...
I've puchased a dedicated Raspberry Pi power adapter from ThePiHut  :angry:  :angry:  :angry:
It's rated 5 volt  2 amps !!
What the hell...
Change the USB cable then, if you'd bothered searching first you would have found these answers for yourself.
Could it be a heat problem instead ??
I've put the Pi into a FLIRC metal case... but it seems rather warm, compared to when i hadn't cased it  ...
Thank you so much...
Those kind of helpful remarks really make the internet better !!!!
btw... this is the power supply im using:
http://thepihut.com/collections/raspberry-pi-power-supplies/products/eu-micro-usb-power-supply-for-the-raspberry-pi
People with your attitude make it worse, take what you give!
The RPi1 and RPi2 aren't the same with regards to how picky they are about power, I suffered with odd glitches until I replaced my USB cable, even though it was powered by quality 5V 2A power supply.
You ASSUME that i haven't researched the power supply issued related to Raspberry Pi - and the matter of bad USB cables
You then give me an asshole remark - to a fair question that aren't easy to research...
I did a search for RGBY square in this forum and came up empty - so i had no clue what the square was all about....
the last thing i need is a remark like yours.... why did you even bother writing it ?
Both of you should know better than to argue on forums...
https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=82373
Is all the information you'll need about the coloured square.
You then give me an ####### remark - to a fair question that aren't easy to research...
You have already admitted that you didn't bother reading any posts https://forums.plex.tv/topic/159291-rasplex-060-released-issues-and-feedback/?p=954910 if you had you would have found several references to this issue and the resolution.
No im sorry... Next time i want to ask a simple question, ill read 278 posts before even thinking of posting a question.... especially if searching doesn't find anything
