Weird Graphical Problem with Plexamp on Windows 10
grafik
Ive got a weird graphical problem with Plexamp on Windows 10!
Any Idea how to fix this problem?
Also no idea where this Topic goes so a Mod might move it to the correct Category?
Thank you.
Did you enable scaling on your display?
Like, you have a high resolution display and you need to scale up the user interface of apps in order to be able to read the text etc?
Try the various compatibility options (right-click on the plexamp icon) of Windows.
