Asustor AS5304T
Plex Web or Plex for Windows (vpn on or off)
My CPU on the NAS runs pretty consistently. Nothing playing 1%. Direct play inside the network 3 to 5%.
But, inside the network with nothing playing the CPU goes from 1% to 40 or 50% as soon as I open the dashboard. And subsequently goes back to 1% as soon as I exit out and go back to the home screen. The CPU stays high as long as I have the dashboard open.
Hi Volts, thanks for your response. I did what you suggested which was a good idea, and it did help slightly. 50% cpu down to about 30% but something still wasn’t quite right.
I performed the following steps.
I did NOT update the server
I did NOT update the client apps
I changed NOTHING on my network
About 2 days later I checked the dashboard again and it was riding at 0.65% and has been fine ever since
