Hi there had this issue since last night the server is not working I can access the drive through Windows and add files to it, it says the server is active on the settings page.
1.16.3.1402-22929c8a2
Plex Media Server
Western Digital Monarch 32-bit Mini
Android 6.0.1
Sometimes turns on for 30 seconds or so then turns off again?
Worried about uninstalling it as will loose all my metadate and cover settings.
Can’t even login to the web app at times.
I have rebooted the drive a few times and rebooted my router neither has made a difference.
Never had any issues before and nothing has changed unless the server updated itself?
Not sure how to get the logs as the app doesn’t stay open long enough and not sure if you can get it another way with these NAS drives ?
Is it an issue with Plex right now or is an issue my end?
Please help.
