What does this icon/setting mean and how do I disable it?
Server Version#: /
Player Version#: 4.29.2
Hello I have this setting in my plex media player windows version and do not know what it is or how to get rid of it. I cant see it in the web app, only on the media player application.
It has the name of one of the servers I have access too, its not mine though and I dont use Plex server windows at all. It has a spinning/loading icon next too it. I thought it is watch/rate sync, but I disabled that now and its still there. Sorry if my question is a dumb one, but I would love to fix it.
Imgur
What particular icon/setting are you referring here?
If your question is about the “fantasia-beta” entry… it appears that’s the reference of a Plex Media Server associated with your account.
As a side note… you might want to upgrade your clients.
The Plex Media Player has been discontinued some time ago and has been replaced by 2 Plex apps:
  1. Plex for Windows → regular desktop player (where you’ll also be able to manage server settings etc., same as with the web app
    Formerly Desktop Layout.
  2. Plex HTPC → the big-screen app
    Formerly TV Layout.
Yes I am referring to that. I got rid of it now by deleting access to the server, still weird as I was only a shared library user and not the owner of it.
Thanks for the tips about the new clients, when I installed everything, I was told Plex media player was the cleanest solution for end users, if you dont have a server yourself. Will update to Plex for windows now though, thanks again.
