Plex Server Settings Unavailable
Server Version#: 4.22.1
Player Version#: 1.6.3.1009-57cf57c8
I am getting the message ‘server settings are unavailable’ on both the web client and the desktop app. I have lost all my matches and it is driving me crazy. This happened after the last update and although I can still access my media without any issues I cannot make any edits or system changes. Any advice would be appreciated.
I had the media player installed and I saw the notification bar saying that it would be discontinued and we have to move to Plex for Windows. I install this version 3 times, and removed AppData/Local directories.
Plex is not reachable.
Make sure your server has an internet connection and any firewalls or other programs are set to allow access.
Plex for Windows
Windows 10 or later (64-bit only).
1.6.3.1009-57cf57c8
January 30, 2020
How can this app know where to get my server if I did not connect to it. If I uninstall it and remove AppData, why it still does not show a login modal?
I wish I did not install this version. I always forget the risk of trying new things from Plex team. Plex Media Player was not working great but at least it was working. Now I have to use the web app.
At least your forums are great and always work perfectly, good job with it.
The newest PMS version is 1.18.7.2457, what version are you running? Is see your using a Windows Player 1.6.3.1003
