I think you still do not understand…
graphics/gaming performance does not matter for plex.
buy the cheapest of those 4.
Thank you very much. I got it now. Any advice about power supply too. Currently I’m using 320w PSU.
cheers
I would simply suggest you add up the watts of all major components (cpu/gpu/motherboard/drives) and use an applicable PSU with some extra to spare.
MSI recommends 450 W for a 1660, so your’s might be a little bit to weak.
You can try it and see if works out and if not, buy a stronger one.
Thank you very much. Then I will try it with existing PSU. I hope It won’t blow up
Thank you very much. What do you think about buying a used/preowned graphic card? do you recommend it?
cheers
As with buying anything secondhand buy at your own risk
Hi @Anuruddha,
I am not an expert but most people use NVIDIA Quadro P2000 or the 4000 model.
I think Plex has some issues to transcode from 4k to a lower resolution… so I am not sure that it will work.
Hope you can find a solution… If you do please leave a message.
BrazMan
noted. thank you.
yes I heard it too. But nvidia quadro p2000 and p4000 cards are very expensive. I don’t have that much for budget
Yes I will let you know If I find a solution.
cheers
Check out the p2200, it’s a bit cheaper and a bit faster
Thank you very much. But It’s expensive too.
Hi guys I’m back. I have a major issue to upgrade the power supply of HP Elitedesk 800 G1. Workstation comes with HP custom PSU. So only option is using 24 pin to 6 pin adapter (https://www.moddiy.com/products/HP-EliteDesk-800-PSU-Main-Power-24-Pin-to-6-Pin-Adapter-Cable-30cm.html) but It looks like it has HP 515 error on boot. I have ordered sata 15 pin to 6 pin PCIE power adapter and sata 15 pin to 8 pin PCIE power adaptor from ebay to give external power to VGA.
In my pc, it has
So what is the best graphic card for 320W PSU?
Some people suggests Nvidia Geforce 1050ti. But I’m looking for best card I can go with external power
cheers
Recently I bought a MSI GeForce GTX 1660 6 GB ARMOR OC VGA card.
What is the best ATX PSU for 24/7 running workstation?
Please help me guys.
Thank you.
cheers
