What is wrong here
Plex does not se this files, and I cant get whay!
(/uploads/default/original/3X/c/e/ce328e1e0e0b5b65f2895a2c5a77b219ebc12bcf.png “”)
support.plex.tv/articles/200220687-naming-series-season-based-tv-shows/
A couple of possibilities…
From the screenshot, it looks like you might be downloading directly into a folder that Plex monitors. That usually, if not always, is a bad idea. Plex will try to match the incomplete file and fail. You should probably move the files into the library only after completely downoaded and named properly.
Sometimes, for no rhyme or reason, the year has to be included in TV series for Plex to match. Possibly the folder should be named:
Into the Universe with Stephen Hawking (2010)
All files are maed doring downling with an extra ext .!ut So PXEX will ignore them
And in that ‘mapp’ is 92 more TV schows all working perfect
With and wiyhout (2010) year paranteses
I found it :slight_smile:
PXEX IS smart
It was a 2nd copy with some diffrent filename, but PLEX find out it does not ‘need’ this one
