Server Version#: 4.116.1
Player Version#: 1.32.8.7639
In my TVShows folder each show has it’s own subfoler by show name. Under that is folders for each season. In a season folder is the episodes named “SxNN - Episode Name,avi”. AVI for this show, anyway. For some reason the tv show, “Bewitched” is skipped when creating the library, when rescanning, and even if I specifically add that folder.
If you’ve many movies/shows to name, there are tools that can help. Filebot is popular. The free version of Tiny Media Manager works quite well. There are many others as well.
Movie Name: ${movie.originalTitle} (${year}) {tmdb-${movie.tmdbId}}
PowerRenamer in Microsoft Power Tools is helpful for simple renaming with pattern matches or regular expressions. It makes quick work of tasks such as adding a year to file names, removing undesirable text from multiple files, etc
PowerRenamer example. It searches the entire tree. You could launch it against /tv shows and it will search all shows. There is probably a limit at some point (out of memory, etc), but I’ve used it to rename 30 - 40 files at a time.
I’ve used Tiny before and it is how all my files got sorted for Plex in the first place. When I specifically add only the Bewitched main folder, it does want to change the subfolders from
“Season # Complete” to “Season #”
Then for the files it shows them in the old format “1x01 - I, Darrin, Take This Witch, Samantha.avi” and it’s suggested renaming to “Season 1\Season 1 - S01E01 - 1 I Darrin Take This Witch Samantha.avi”
So how do I get it to be “Bewitched - so1e01 - I Darrin…”
