Where are Storage Options?
Server Version#: 1.20.1.3252
Player Version#: Any
Tuner Make/Model: HDHomeRun Prime
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Where are the settings for where Live TV is stored when using DVR? When I search for this I find a bunch of old posts with settings and options that I can’t find anywhere.
This is determined by the “Add to Library” option when configuring individual recordings:
It’s considered a best practice to keep your DVR recordings separate from other libraries, i.e. both TV and DVR TV libraries. Though you can record to your existing libraries if you desire, it may have unintended consequences.
Also keep in mind that series have to be recorded to a “TV Shows” type library, while movies must be recorded to a “Movies” type library.
Thanks.
