Where can I get previous plex releases?
I am running latest PMS. having issues. Want to roll back
more info is needed.
rollback on which platform?
Thanks. I found links on git.
Linux.
All good now.
Now to wait for issues to be fixed
Newest plex hangs on media scans.
where on git?
I also need to roll back.
Since moving from to 1.25.5.5492 (running debian amd64 build) i am experiencing issues with alexa/sonos integration. 95% of the time alexa (and sonos) ‘claim’ that it is playing my plex music, but i get no sound and occasionally a random error about invalid token or audio fiietype.
This is something that occurs quite frequently with updates to PMS (understandable, it is presumably quite difficult to fully test for the integration of two simultaneous third party interfaces) and is usually sorted by the subsequent release.
I also used to have to do this back when camera upload still worked (crying face > angry face > acceptance face).
This used to be easy as you could list previous versions using “apt list -a” but that appears to only show the latest version (perhaps plex are purging old verisons from repositories as they go? i must admit i don’t really know how it works)
I am confident that rolling back to 1.25.4.5487 will resolve my issue, but my usual “apt list -a plexmediaserver” only returns the most recent version, so i think i have to roll back another way?
can’t find a .deb for xxxxx.5487 though.
Here you go:
