Where did the guide button go for the dvr?
When I go into the dvr section all I get is the browse view. I can’t seem to find a way to view the guide. This is on plex web in any browser
If you widen your browser, do you see other options (tabs across the top)? Or if you click on “Browse” do you get a dropdown?
If not, you can try resetting customization:
Settings -> (Web Client) General -> RESET CUSTOMIZATION
Alternatively, you can try using the local IP address (something like http://192.168.1.12 or whatever your IP address is for your computer that has PMS installed) instead of the host URL.
No browse button at all. No drop down. Did the reset customizations. didn’t help. Don’t see a good way of sharing a screenshot.
Just drag and drop into the edit window.
Also, what url are you using?
I’m using my local hostname. I"m not going through the plexweb unifier. When I click on the live tv/dvr button the url it uses is. http://vault:32400/web/index.html
that looks like a Movie library that is named “Live TV & DVR” based on the filters available
it should be in the same place.
If this is indeed your Live TV & DVR section, try Settings -> (Plex Web) -> Debug -> Restore Defaults. Mind the warning. This should restore the tabs in the Live TV & DVR.
that fixed it. thanks
