Where does Plexamp on Android store downloaded music?
I found several posts on this topic:
but I cannot find the files. I looked at /storage/emulated/0/Android/data/tv.plex.labs.plexamp/ which contains only an empty directory named ‘files’. I had display of hidden files on.
I am aware that the files do not have their original names.
Where does Plexamp store the files on Android?
Phone: Galaxy S9
Android: Stock Android 10
Plexamp: 4.10.1
Depending on the storage setting, it stores on external SD card, or internally along with local app settings, cache, etc.
I have a similar problem (oneplus7) but I don’t think your reply addresses the question. The folder your referencing would be called ‘files’ in the above example. Can you provide any clarification? This has been quite a challenge. In the cache folder is only the Dev log dumps. Is there something missing here that I am not understanding?
