Where does Plexamp store downloaded tracks?
Player Version#: 3.3.0
On a Pixel 4a, I downloaded a single track in Plexamp.
I looked in /sdcard/music expecting the tracks to ideally save here in an Artist/Album/Track folder structure.
Next I looked in /sdcard/Android/data/com.plexamp.android/files/ with no luck either.
I would gladly accept sdcard access permission in Plexamp, to be able to select /sdcard/Music as a download location for my music. This has the added benefit of making downloaded music available to other applications the user has installed on the phone.
depends on whether you have external SD setting enabled or not; if so, it’ll be inside the app’s data directory in Offline/ or some such thing, with a directory per downloaded item. If you have enabled SD storage it’ll be in a similar place, but on the SD.
the downloads aren’t named/organized for use by other apps.
