Where is Guest DJ?
The Guest DJ feature showed up when I first installed Plex Amp, now I can’t find it. Where is it? Also, what Lyrics? Can’t find that either. I have a Plex Pass so should have access to these features.
Ok, I found Guest DJ and Lyrics. Guest DJ doesn’t seem to be working. I’ve tried several and none seem to do anything with the queue.
Would be nice if there were some help files on the app.
The Guest DJ will only do its magic for the next transition. The queue will be updated on the go, not all at once.
Still not working for me.
DJs Stretch, Gemini, and Freeze require that sonic analysis be completed for your (entire?) library. They rely on sonic analysis data to find sonically similar tracks and insert them into the queue in different ways.
I think you should be able to test with either DJ Twofer or DJ Groupie though as they just add songs by the same artist to the queue (either one for Twofer or multiple for Groupie). But keep Tom’s advice in mind, the play queue may not be immediately updated.
