hello, sorry if the post is in the wrong section but it is the first time that I create one, so sorry
I have been having a problem for a week or so, everything is ok on my pc, but in the tablet or phone in the library I created I can’t see the items in the folders, I only come to the library (genre, year, actor, etc.) here once there was another option with “folders” to see folder by folder, now it’s gone
how can i fix it? I state that I have not updated plex server, and in the phones various updates but the problem comes to me on all and all the latest versions
What happens if tap on the entry directly below of “Film”, named “Raccolte”?
it is where the folders should be, but it is empty
After tapping on it, you need to close this filter window, by tapping on the ‘Back’ ‹ chevron
If so, I doubt whether it is an application bug since you iphone have the “folders” section in the category.
must be a bug for android
What do your actual Movie library folders look like. Is each movie in their own folder? If the individual movies are not in folders then folder view won’t show anything.
there is a screen shot above of android showing folders
yes I have always seen them, every movie is inside every folder, from pc I see everything correctly, the problem is from android phone
I’ve got one that shows them just like that. <—just Movies in Folders here.
(I couldn’t get away from that view fast enough, but they did show)
above I put the screen of my library inside “raccolte” but it is empty, once there was “folders” and it showed all the folders from PC, I don’t understand the reason that they replaced “folders” with "raccolte " making it empty
plex is set correctly because from pc i see everything as it should be, but the problem is only in the latest versions of plex for android
do you all have iphone or does someone have android to see if he does the latest versions of android too?
My Folders on My Android Phone show.
My Folders aren’t called ‘Raccolte’.
I’m not switching my language to Italian to find out what happens…
I don’t know what to say, before I always saw without problems now no … boh idk
I understand the problem and don’t doubt your word.
Someone needs to replicate your conditions and see if they can reproduce the issue - and that’s above my pay grade…
I will suggest, not reading if you have already:
Uninstall the app - reboot the phone - then re-install the app (old Roku Trick).
… at this point - what do ya have to lose?
Sometimes these Android apps don’t get here in one piece - it seems… take another whack at it and hope for the best.
I would have done it already but this happens on 2 phones and a 1 tablet, probably there must be something bugging the interface in Italian
I will try to wait for a new fix / update
thank you
We have yet to identify the bug.
The only one seeing it is you.
If that doesn’t change - there won’t be a fix for an issue no one can replicate.
Blind Luck never works out the way you want it to - in the Plexiverse.
Why don’t you take a screenshot of what you do see when you select Raccolte from the menu.
there is nothing, empty
