Ive just updated PMS to Build 1.16.1.1291 as suggested by Plex admin via the notification and as a result the channel List only showed 22 available channels of the 96 available. These appeared to be the HD channels. I therefore re-scanned the channels but it would not populate any further channels.
I have therefore bit the bullet and deleted my HD Homerun NVR and set up Plex DVR from scratch. I now get the full range of OTA programs picked up by HD Homerun. The problem I am having though is that despite entering a London postcode I am only offered East Anglia or East of England programme data. For example against BBC 1 I now have either BBC 1 Cambridge or BBC 1 East neither of which are right. I also dont have access to London Live which maps to Thats TV.
Can someone suggest a way to get the London EPG data that I had before updating Plex?
Many thanks
Fozzie
Is there any forum member from London UK (or the northern home counties that uses a London TV transmitter) that has been able to successfully set up a DVR with the correct OTA Guide?
If so which of the various regional guides did you select during the setup process?
My HD Homerun has correctly identified all the channels which are transmitted from Crystal Palace but none of the guides offered when I enter my postcode are London centric guides. Currently BBC 1 is mapped to BBC East which was not the case prior to upgrade to Build 1.16.1.1291
