Server Version#: 1.40.2.8395
Player Version#: 8.34
Hi all, I’m not sure if this is a known issue with Plex so any help would be much appreciated!
Every now and then, between every 30 minutes and every 5 hours, I get a white line about 40-50 pixels tall flickering across the entire width of my screen when watching media through Plex. It lasts a couple of frames, then disappears again.
Did you try the fix that’s in that 3 year old reddit post? "
I unintentionally solved this issue while trying to solve another unrelated issue. My desktop power settings somehow got changed to “Balanced”… I switched it over to performance mode and no more issues!"
No correlation to media type - it happens on a 1080p Seinfeld episode in SDR as well as a 4k John Wick film in HDR. It can be 2 minutes into a title or 2 hours in, and not something I can reproduce - if I rewind 10 seconds and then play it back, the band/line/stripe doesn’t appear at the same point.
Ok, then that would suggest at least, it’s not server or media related. It could be a bug in the player version, a bug in the player firmware, maybe a bad hdmi cable from the player, etc.
I’ve narrowed it down to being a bug in the player, there’s no doubt about that - but I don’t know if this is a known bug, if other people are experiencing it but haven’t reported it, or if there’s a fix in the works.
