Server Version#: 1.40.1.8227
Player Version#: 4.10.1
97315031333084.zip (185.2 KB)
Please see attached ZIP for all logs from my PlexAMP
It’s not wrong.
These are the addresses it’s trying:
Apr 05, 2024 14:32:13.364 [Javascript] WARNING - DEVICE: Server connection https://172-18-0-1.dd65f68d03de43838d3ef5ab14a93496.plex.direct:32400 didn't work for ConnorsMediaServer: HTTP status -7
Apr 05, 2024 14:32:13.366 [Javascript] WARNING - DEVICE: Server connection https://192-168-1-107.dd65f68d03de43838d3ef5ab14a93496.plex.direct:32400 didn't work for ConnorsMediaServer: HTTP status -7
Apr 05, 2024 14:32:13.366 [Javascript] WARNING - DEVICE: Server connection https://172-19-0-1.dd65f68d03de43838d3ef5ab14a93496.plex.direct:32400 didn't work for ConnorsMediaServer: HTTP status -7
Apr 05, 2024 14:32:13.366 [Javascript] WARNING - DEVICE: Server connection https://159-196-130-110.dd65f68d03de43838d3ef5ab14a93496.plex.direct:32400 didn't work for ConnorsMediaServer: HTTP status -7
That makes it look like there’s an issue with your server and networking. Make sure your setup is green, otherwise you won’t be able to access over cellular.
Hey Elan,
I have been running this same plex server since 2017 and all of the other numerous devices that access this server all connect fine, through LAN or WAN.
For some reason its only my android phone that has this issue, sometimes I need to use Tailscale to get into my network to get a connection again.
I don’t know what to tell you except there is a fundamental issue connecting to the server, at a low level.
Hey Everyone I just thought to come back with my solution, it seems like my Celluar provider, Telstra in Australia was blocking the direct ip that Plexamp uses to talk to my server, I resolved this by using dns.google.com in the private dns section of my Android Phone.
Hopefully this helps anyone else out that is having this weird issue.
thanks for letting us know!
