4G issue when using Plexamp
Server Version#:
Hello everyone,
I am facing an issue recently : Plexamp is not working in 4G connection but works perfectly with any other wifi connection.
I have checked my cellular network data and it is working fine. I am not sure what can be the issue for this topic. No issue when using the Plex app.
Thanks a lot for your help.
Plexamp Log.zip (186.9 KB)
Did anyone faced any similar issue ?
It’s having issues connected to:
Jun 01, 2022 12:44:15.174 [Javascript] WARNING - DEVICE: Server connection https://94-239-132-252.2c7f2a4e6684440ea6190bd2afedf56d.plex.direct:32400 didn't work for Karavela Home Server: HTTP status -7
Status -7 means it literally couldn’t create a connection. Most likely is your mobile ISP is blocking. Best idea is to run your server on a more “neutral” port like 443 or 8443. Plex is known to default to 32400 and so easier to block.
Alternatively, you may not have properly exposed your home service to the internet.
