Why are my lyrics not working?
Hello all,
I’m sorry if I’m wasting one thread on the forum but it’s 3 months I’m trying to get this to work and I have no clue what to do next really.
My problem with Plex is that Lyricsfind automatic download is not working and, also, Plex fails to display some lyrics that have been added manually to the music folder.
My music collection is split into two main folders (/media/flac and /media/mp3). I have now tried to play a song (Iron Maiden - Aces high) and no lyrics are downloaded automatically.
The timestamp when playback started is 6.39 am GMT and the path to the file is “/media/mp3/Iron Maiden/Powerslave/01 - Aces High.mp3”.
At first I thought it was a problem with the LyricsFind plugin, but then I realised that even manually sideloading the lyrics file in the music folder is not working properly.
I have this folder with the following content:
root@plex:/media/mp3/Os Mutantes/A Divina Comedia Au Ando Meio Desligado # ls -la
total 59722
drwxrwxrwx 3 1000 1000 26 Nov 11 14:57 .
drwxrwxrwx 6 1000 1000 6 Dec 19 2015 …
drwxrwxrwx 2 1000 1000 13 Dec 19 2015 .mediaartlocal
-rwxrwxrwx 1 1000 1000 6927585 May 10 2016 01 - Ando Meio Desligado.mp3
-rw-r–r-- 1 1000 1000 300 Nov 11 14:38 01 - Ando Meio Desligado.txt
-rwxrwxrwx 1 1000 1000 5461789 May 10 2016 02 - Quem Tem Medo.mp3
-rw-r–r-- 1 1000 1000 578 Nov 11 14:55 02 - Quem Tem Medo.txt
-rwxrwxrwx 1 1000 1000 3430505 May 10 2016 03 - Ave, Lucifer.mp3
-rw-r–r-- 1 1000 1000 594 Nov 11 14:39 03 - Ave, Lucifer.txt
-rwxrwxrwx 1 1000 1000 4107603 May 10 2016 04 - Desculpe, Babe.mp3
-rw-r–r-- 1 1000 1000 263 Nov 11 14:46 04 - Desculpe, Babe.txt
-rwxrwxrwx 1 1000 1000 9167632 May 10 2016 05 - Meu Refrigerador.mp3
-rw-r–r-- 1 1000 1000 785 Nov 11 14:46 05 - Meu Refrigerador.txt
-rwxrwxrwx 1 1000 1000 4081258 May 10 2016 06 - Hey Boy.mp3
-rw-r–r-- 1 1000 1000 695 Nov 11 14:46 06 - Hey Boy.txt
-rwxrwxrwx 1 1000 1000 5598476 May 10 2016 07 - Preciso Urgentemente.mp3
-rw-r–r-- 1 1000 1000 481 Nov 11 14:56 07 - Preciso Urgentemente.txt
-rwxrwxrwx 1 1000 1000 4666837 May 10 2016 08 - Chao De Estrelas.mp3
-rw-r–r-- 1 1000 1000 871 Nov 11 14:57 08 - Chao De Estrelas.txt
-rwxrwxrwx 1 1000 1000 6010365 May 10 2016 09 - Jogo De Cal??ada.mp3
-rw-r–r-- 1 1000 1000 733 Nov 11 14:50 09 - Jogo De Cal??ada.txt
-rwxrwxrwx 1 1000 1000 5323854 May 10 2016 10 - Haleluia.mp3
-rw-r–r-- 1 1000 1000 128 Nov 11 14:57 10 - Haleluia.txt
-rwxrwxrwx 1 1000 1000 6304404 May 10 2016 11 - Oh! Mulher Infiel.mp3
-rw-r–r-- 1 1000 1000 172 Nov 11 14:57 11 - Oh! Mulher Infiel.txt
root@plex:/media/mp3/Os Mutantes/A Divina Comedia Au Ando Meio Desligado # file {06,07}*txt
06 - Hey Boy.txt:              UTF-8 Unicode text
07 - Preciso Urgentemente.txt: UTF-8 Unicode text
Here, most of the songs will display their lyrics except for 2 or 3, however there is no difference in the file format/permission. For example, track 6 will display lyrics correctly while when playing track 7 I can’t even click on the lyrics button.
I played track 6 of this folder at 6.47 am, and track 7 at 6.50am today (so you can probably find it easier in the logs I’m attaching).
I would really like to fix this issue as this feature is one of the reasons I moved to Plex but, if this won’t work I’m afraid I’ll have to look for some alternative as the Android app doesn’t even have gapless playback.
Thanks in advance for your help.
The lyrics from LyricFind are not downloaded at playback. They are downloaded when you add the tracks to your library, assuming you have the LyricFind agent enabled.
I’m not sure how the local lyrics work, I’ll need to check. But could you provide me the lyrics for 6 and 7 so I can try to reproduce the problem.
Local lyrics need the ‘Local Media Assets’ agent to be active.
If you add lyrics after the album has already been added into Plex, you need to ‘Refresh’ the album for the local lyrics to be recognised.
If you are on a platform which has trouble with non-ascii characters in file and folder names, local lyrics are affected by the same issue.
