Why don't files stay locked?
After I am done editing the file and click the orange lock button, later it just changes back to what it wants when it updates.
I initially had some trouble with the “lock” feature. But, it’s quite simple. If the lock is orange it will remain locked. If it’s gray it will revert back.
For me, I found that while I was typing something to change it a drop down would pop up with what I was trying to type. If I did NOT select the drop down, it would revert back no matter what. (not sure if that is a bug or not) Once I started selecting my title from the drop down list and made sure the lock was orange it stayed.
Hope this helps.
-Amp
see Can anyone tell me why the metadata ‘lock’ does not actually stay locked?
My experience has been that sometimes the drop down title shows up and other times it doesn’t. I have yet to determine why the inconsistency but agree that if you click on the drop down after you type it the lock will work, if you don’t click on the drop down the lock won’t work.
