Why get not the Beta?
I have sign for days but dont get the Beta. I am Plex Pass User too and i use Android TV.
I am waitĂ­ng for a answer???
Hi there.
If I remember correctly, the team will manually import all registration from the Google Form “beta access” to the Google Play beta platform.
If that is your problem I think you just have to wait a week or a bit more.
Problem is solved and working now today.
Why the hurry to update to the beta releases??? Is there something that was added or supposedly fixed in the beta release you want or need to make PLEX work for you??? Beta releases can be buggy…
I signed up for a lifetime pass a couple years ago and have never installed a beta release… I don’t even update standard releases until a week or so has gone by while checking the forums to make sure there are no problems or at least reasonable work around for a problem before updating anything…
Only Beta have DV Support.
great, you can mark this topic as solved then :slight_smile:
How mark?
Under your message “problem solved today” you can tick
“Solution”:
Hi at all,
I have the same problem i would like try beta version, and i have buy Plex Pass.
I don’t recived e-mail after compiled this: Join App Betas: Android (mobile), Android TV, Apple TV, iOS
can someone help me?
Thanks in advanced
You’ll have to wait some days until you get activated. Just be patient :slight_smile:
Per the form:
Requests are processed prior to making new releases available
ok, thanks for your answer, but i have wait for 1 week and I don’t recived e-mail, it’s normal?
Yes, in my case it took around 7 days
2 weeks have passed and no email has been received :thinking:
can nobody help me? 3 weeks have passed and still no email to participate in the beta program I am a Plex Pass user.
