ok ill check out makmvk i been using still dvddecrypter all this time
thatās the magic bit.
You FIRST obtain the raw streams in an MKV file with MakeMKV (as the name suggests).
You then see what you have in the file, use what you need when you drop them on Handbrake, create a āQueueā of, what could be thousands, to run⦠and run⦠and run⦠and⦠you get the idea.
I have a dozen running now.
Try it - youāll like it.
ok  ill have to read up on it slowly
as i know i asked before other groups
handbrake cant fix my avis moi files  it makes them smaller but i liked handbrake as its was automatic
then god told another it doesnt do batch⦠then was told avidemux   it can do batch but u gotta write a script⦠and i just trying this mvktoolnix  and it seems it takes 5 files and shoves it into 1 file lol  1 video and takes the audio  from the 5 files and all into one
is there a script  then i could use  as i know i have more then 100 avis i dont wanna sit there loading 1 file at a time  i
or do you know how to make handbrake   change the container from avi to mkv  as i only been told  it just re encodes  so was told you loose quality⦠but i was hoping one of these automaiticlly did it and keep the same subdirectories tooā¦
but ill read up on the other links too
so looking at the makemkv site⦠is like dvd decrypter⦠rips the dvd to the hard drive
and then you save which files to keep rename it⦠right so if it rips to mkv  you dont need handbrake?
but im sure i missing something lol
You got it.
ah ok and is there a script or something i not good at the coding that i can just download
i just wannna say then mkvtoolnix    point to   \movies   or
point to  \old movies\   (all my movies)   (input)
point to  \movies\         (all movies converted to mkv)  (output)
and it fixs  all movies avi mp4 moi   and dumps it to the mkvā¦
as i tried to ask for help in avidemux but i never got help⦠.as i was told to use that with a script well doesnt help me when i dont understand it lol
Slow downā¦
Do a few and see if they work.
When/if you need to do large batches (like the 1300 I just did) you stack 'em on
- Drag and Drop - in groups you can manage (until you get 5-10 tabs or so) then you seek out the Action For All Tabs Button:
Note: that will command a large portion of your driveās usefullness - particularly the one all this is happening on. Small batches recommeneded.
ok ill re try later
what i did was i clicked the bottom  Add Sources  i added 5 files
then i click the button beside is Start multiplexing
and destination file said the 1 file⦠    and it took the 5 video audio files and stuck it into the first fileā¦
Just drag and drop a few on the GUI - anywhere - itāll add tabs and you can do the tab trick.
just do one first and test it.
guess ill have to try to get it for Windows
when i install  MKVtoolNix
it only installs version 8.7.0  but you have a newer version and it tells me newest version is 46.0.0  im as download to get latest verion  for unraid  doesnt go past 8.7.0
juicy  i have a question
so i had to get a windows version⦠since its not supported on unraid reason its only version 8 not 46⦠   so i been fiddling with it⦠  all i set was keep in the same directory  as it didnt work to make another folder  and keep the same as the directlyā¦
but couple questions⦠as i converting all my mp4  divx avi flv to mkv
so the āfailedā means  it cant read the audio and cant do the file right?
and the āwarningā  mean it  tried it finds garbage in it for the audio but the audio seems to be ok still
and you said you can load 1300
i try to load up more then 400 avis and the software i guess is trying but crashes⦠ how do you manage to load up 1300 without it crashing  as i have alot of AVIs id like to upgrade to mkv
I did 10 at a time - not 1300.
(it took 2 Weeks - Not 15 Minutesā¦lol)
Some AVIs canāt simply be remuxed to cure them.
Some AVIs must be re-encoded for the cure.
Another reason to hate AVIs.
(as if I needed one)
oh lol i thought you loaded up 1300 in one shot lol
so does remuxing mean  it rencodes an old format into a newer format?
i didnt know avis were bad⦠well back 20 yrs ago all i had was avi and moi and divx coming out so i always stuck with that using gordenknot to encode my dvdsā¦
is mkv the best format now as i seen mts mp4 m4k like how many formats are there lol
MKV files are more versatile than MP4s.
There are quite a few container types, but most of the ones that work on most everything are MKV and MP4⦠depending what the streams are within them as that is whatās important.
AVI files suck all around and should be replaced with ANYTHING else.
what does mkv do over mp4?
ah well avis better the moi my camcorder older one records in moi friging windows media player cant play them have to use vlc player just to play it lol
its a headache also (:
There are differences many not worth mentioning, but MKV files are able to contain multiple tracks of the same type - MP4s not so much.
Playback support on many devices was once more reliable with MP4 files, but today, that isnāt so much an issue.
Today, an MKV file is preferred, if you can use it.
You can do more stuff with it.
ah ok  so not necessary to convert the mp4s    just the avis and my moiās  must been a JVC camera format lol
i apprecaite all the input  just wished this thing could load all the files up but thats ok
as i never figured out how to write a script for avidemux   but im guess they both the same thing they refix the orginal video into a new video
i also remember the common format for devices was divx⦠like you had to find a dvd player that supported dvix lol guess thats no longer lol
i have another question maybe you know or not,., does this program or is there a program can tell you if there is any corrupt videos i may have and flag them?
1 last question
do you know of a bulk meta tag deleter⦠i been using mp3tag  but it loads up mkv but title shows up blank  but in vlc player the title still in it⦠ is there a program  loads up all and deletes it⦠as i converting everything to mkv  but wanna deleted all meta tags   so plex doesnt have any issues later
