2 different movies but considered duplicate of 1 movie how you fix?
hi i have a few movies plex is saying its a duplicated of 1 movie but they are 2 different movies… if i do the split apart button the 2nd movie isnt detected by plex or the file name isnt even added
first example is
First Blood (1982).avi
It Came From Hollywood (1982).avi
plex sees the comedy movies as Rambo and when you click spilt apart it cant be found
2nd one… Plex sees these both as duplicate of Strike back
Jay And Silent Bob Get Old Tea Bagging In The UK (2012).avi
Jay And Silent Bob Strike Back (2001).avi
i have more but that just a couple… and why doesnt plex let you do the “fix match” to multiple duplicates instead of just the first file of the dups… there is no way to fix match of the 2nd one…
i tried to adjust the agents for the movie naming but didnt help… frustrating
Please show the folder structure you are using.
Are all your movies together in the same folder or are you using one subfolder per movie?
Do also look out for .nfo files. If you have those in the same folder with your videos, it can throw off the matching, if it contains an IMDb ID that doesn’t fit the movie.
If your files were previously named differently (and caused mismatches), you need to dance: The Plex Dance ™
nope dont have any nfo files
files are located as follows
  • /Videos/Movies/Action/Rambo/First Blood (1982).avi [ Delete Files]
  • /Videos/Movies/Comedy/Cheech and Chong/It Came From Hollywood (1982).avi
  • /Videos/Movies/Comedy/Jay and Silent Bob/Jay And Silent Bob Get Old Tea Bagging In The UK (2012).avi
  • /Videos/Movies/Comedy/Jay and Silent Bob/Jay And Silent Bob Strike Back (2001).avi
What about the .nfo files? Have you checked for them?
“Tea bagging” is not a movie. Which could explain why it may get mismatched.
At which folder did you direct your movie library?
/Videos/Movies or /Videos/Movies/Comedy?
if i move the files say
to
  • /Videos/Movies/Comedy/Jay And Silent Bob Get Old Tea Bagging In The UK (2012).avi
  • /Videos/Movies/Comedy/Jay And Silent Bob Strike Back (2001).avi
no change it still finds it as a duplicate movie
ill try the plex dance now to see if that fixes it
/videos/movies is the root for movies
oh so tea bagging is a tv show then?
and ya i searched for nfos i dont keep any and i rip my dvds to computer so no nfo’s
According to IMDb it is a TV Special (what ever that means). But in reality it is a Podcast episode or Podcast special.
if its a podcast how you define that in plex then
and what about the rambo and a cheech and chong movie they linked the same but arent
ill try to move the 1 jay silent bob one
i got other ones… and is there also a way for plex to display the movies or tv shows that werent added to the server since it couldnt find a name for them
I have a suspicion: you are using 2 additional folder levels underneath movies.
Plex is looking at the folder name where the video file is situated to get additional hints for a proper match.
But in your case, the folder name is misleading, because you are using folders to “group” movies.
Try this: add yet another folder level inside the Cheech and Chong folder and give every C&C movie its own subfolder, named just like the file (Movie Title (year))
Then Plex Dance them.
in my unraid server i set the /data root to /videos
in plex when i specify for All Movies i do /videos/movies
in plex when i specify for action movies i set it to /videos/movies/action
in plex when i specify for comedy movies i set it to /videos/movies/comedy
and so on
for tv shows i do
/videos/tvshows/comedy
/videos/tvshows/action
ok ill try that an see what happens
so i tried the plex dance i tried this… it still matchs cheech and chong as rambo
  • /Videos/Movies/Comedy/Cheech and Chong/It Came From Hollywood (1982)/It Came From Hollywood (1982).avi
i fixed a couple of my other dupicates had wrong year but this one is a mind boggler lol
It Came From Hollywood (1982) is also not a movie.
You may want to try setting The Movie Database as default agent for this library. It may have better matching for this type of content.
Or you’re resorting to the .nfo file trick
its it because imdb says its a comedy documentary… so that isnt a movie then?
ya i have the movie database on top
ok doing the nfo and then the plex dance fixed the dupicate
but why does it see it as a dupicate of a movie that isnt the same
and is there a way to list movies or shows plex doesnt recongize or is it just will never show them
ok great fixed all my duplicated issues
i have 1 more question if you know
so i have tv shows broken down as
and so on
in plex i have the shows set action /videos/tvshows/action
and so on
but if i set a folder for All Tv Shows and set it to /videos/tvshows
it messes up big time
i guess it cant do that
and the reason i ask if plex can find other videos is i have off my dvds behind the scenes for tv shows that arent on imdb and arent in the tvdb site when i use a renamer and i wanted to watch them through plex but they never show up
Precisely. Arbitrary subfolders are verboten in tv show libraries.
Are not really supported. see TV show extras not showing up - #5 by FordGuy61
ah ok is there a reason why its forbidden… will there ever be a fix
ah ok so extras no good… will such things as extras and stuff not from tvdb website be an option
i also noticed the tvdb site some of there shows are not in the order they actually were ment to be in … it sucks not 1 website can be acculturate… but hey the program works… i been backing my movies from vhs to computer for years years before netflix and had my own media server… but there was none of this stuff with pictures etc just my file names…
i do like most of the features of plex just wish they improve on some…
thank you for helping me (:slight_smile:
Read through the link. There are several workarounds presented.
ok i see add your own season episode to help
and can you tell me why the Fix Match button doesnt work
i have Loose Change (2005) and loose Change Second Edition (2005)
both linked to same but for Loose Change 2006
i did the nfo thing and that didnt help… i did the Fix Match and choose Loose Change 2005 but it did not do anything
i re deleted the plext folder and tryin again to make sure i get no duplicates
but why doesnt the fix match work really keeps going back to 2006 when i said its 2005
and i know its not a movie its a documentary… but how you supposed to classify them in plex… as i put them under movies option
I can only recommend you to create a separate library for documentaries. Then set TheMovieDB as the primary agent for that.
If you have mp4 files, you also must make sure that they contain either only correct metadata or no metadata at all.
