@Smokindog said:
I switched to station 27.4 to watch “Black Sheep Squadron” about 20-30 minutes into the show and did not get prompted to “Watch from the start”.
I looked in the web guide and the program is set to record. I looked in the Recording Schedule and it’s not listed to record for today.
Here are the logs.
This release of Plex is riddled with bugs from missed recordings to failure of guide updates to transcoding crashes, …
You have disabled debug logging
Please enable it
Save changes
Restart the server
and capture logs when you have the issue and indicate what it was and when
Logs are recycled so please capture the logs soon after noticing the issue
See
https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
Unrelated to EPG / DVR: there appears to be a corrupt Gracemote Premium Music Library database
Mar 31, 2018 19:31:42.691 [11956] ERROR - SQLITE3:0x3ae3023d, 11, database corruption at line 112037 of [fc49f556e4]
Mar 31, 2018 19:31:42.691 [11956] ERROR - SQLITE3:0x3ae3023d, 11, malformed database schema (
/"Tính dữ dội Dark Pop(Ǿ0ŋ8>@̏HP)
Mar 31, 2018 19:31:42.692 [11956] ERROR - Gracenote: Music locale error -1870658241 (CorruptDB: A database disk image is malformed)
Is the M:
drive where you hold the Plex Media Server app data a local drive or network mapped drive?
M:\My DVR\Plex Media Server\
Network drives is not supported as sqlite3 database would easily get corrupted
The gracenote database is probably one of the gdb cache databases which you can delete and it would get recreated. Delete when the server is shutdown
M:\My DVR\Plex Media Server\Cache\gn_colls.gdb
M:\My DVR\Plex Media Server\Cache\gn_cachq.gdb
M:\My DVR\Plex Media Server\Cache\gn_lists.gdb
M:\My DVR\Plex Media Server\Cache\gn_gn_cachc.gdb
If M drive is network drive, please start afresh with Plex Media Server data help on a local drive
and please re-enable debug logging
