@zpaolo11x said:
To be more precise, 480p and 576p should be used only for video that retains the full TV or DVD frame, black bars included. A 16:9 anamorphic DVD, for example, has a full picture of 720x576 pixels that is stretched to 16:9. If the movie displayed is 1.85:1 it will have hard black bars in the frame. If you encode this cropping black bars, although the data is basically the same it is incorrect to call it 576p because it’s nothing like that, it’s another resolution, although equivalent. 576p is a “standard” and anything not adhering to the standard should not be called 576p. So if I hard stretch a 720x576 frame from a 16:9 DVD to have it in non anamorphic resolution, that’s not 576p anymore.
Actually, that is not entirely correct:
https://forums.plex.tv/discussion/comment/1335697/#Comment_1335697
480p and 576p do describe the vertical resolution. The Former NTSC, the Latter PAL.
Correctly encoded NTSC DVD material always has a ‘Storage’ resolution of either 720x480 (Disc) or 704x480 (Mostly Broadcast). Proper Anamorphic settings tell the player how to display this content during playback. Cropping during a proper encode plays no part in it’s ‘Storage’. Widescreen ‘Letterboxed’ material will still be stored at one of the base ‘Storage’ resolutions described above as will properly encoded 4:3 material. It’s all properly ‘Stored’ as above. Properly encoded 4:3 material will have a ‘Display Width’ setting of 640p resulting in a final displayed resolution during playback of 640x480. 640x480 can be hard set without Anamorphic Width settings, but a Commercially Produced DVD will Store 640x480 at 720x480 and tell the player what to do with it when it’s displayed. Properly encoded 16:9 (for your standard NTSC widescreen display) will have a Width setting of 854. Cropping sets the ultimate vertical resolution during playback, but generally a full 16:9 properly encoded item will display at 854x480 and will fill a 16:9 display. Plex can’t read this ‘ultimate’ displayed resolution - I get that. Plex can only look at the ‘Storage’ res during it’s inspection when it’s identified. That is correct and proper. It’s how it’s always worked - until recently.
Correctly encoded PAL DVD material is stored at 720x576 (Disc) or, I assume 704x576 (Broadcast). I’ll admit to not knowing a lot about PAL and even less about what’s pumped into the air, but that’s not important right now. For PAL a properly encoded item at 16:9 will have a Width setting of 1024 resulting in a final displayed resolution of 1024x576 filling a 16:9 display. Again, Plex can’t extrapolate this final displayed resolution during inspection - but it doesn’t have to - it need only look at the Stored resolution to determine what it is.
DVD material for both PAL and NTSC should correctly be ‘Stored’ at one of the base resolutions described above and encoded with proper Anamorphic Width settings also described above for the proper final displayed resolutions - that Plex can’t determine on it’s brief initial inspection. It doesn’t have to. Properly encoded material is always Stored at one of it’s two possible Storage resolutions and it’s flat easy for Plex to see what that is and correctly report it.
In Handbrake, for instance, if you look at a ‘Static Preview’ of a Stored Frame it’s going to look all out of whack because you are looking at the ‘Stored’ resolution - not the final displayed image that’s only visible while the player is dealing with it displaying it on your screen. If you do some serious cropping for Widescreen Letterbox it’s REALLY going to look out of whack in a Static Preview, but that doesn’t matter. You’re only looking at the Static Preview to crop out the black stuff. All normal. Don’t give it another thought.
Every player on Earth knows how to deal with Anamorphic settings for DVD material because it’s the Industry Standard - in use for Decades and will be in use until DVDs are abolished… about the time the Sun eats the Earth I imagine.
I think what is happening is the Plex Developers are trying to ‘Overthink’ this whole thing - messing it up for everybody, but mostly for NTSC peeps who really got the ‘dirty’ end of the stick because Plex decided to call all properly Stored resolutions 576p and that’s just wrong.
