Why not (HW) on both sides for transcoding?
Confused. As of recent it doesn’t show “HW” on both ends of the transcode for the encoding and decoding from my P2000. It only shows it on the decode end. Task manager still shows it doing both which is what’s weird. Newest Nvidia Driver update (436.30) and Plex is up-to-date (1.70.0.1841). . Is this something with Plex’s new transcoder updates?
https://imgbox.com/fnfzlGd4
That is actually the encode side. I would need to see your PMS logs to double check exactly what is going on.
Tautulli is not properly showing “HW” on both sides since the transcoder changeover. Double-check in the status page on PlexWeb.
use @ Plex Web > status
also, you can paste images and stuff directly in to the forum reply, you don’t need to use imgbox here.
Doh. Didn’t even notice those were not Plex Web. Good catch you two.
