Why Plex app is not available for Samsung Tyzen plataform in Brazil?
I have read that Plex is not available for Brazil on Samsung Tyzen but this non sense. Plex is available on the older Samsung Smart HUB and also available on LG TVs with WebOS, Playstation 4, local Google Play for Android phones and TV boxes, Apple Store, Windows Store and many others devices and sources here in Brazil. So, that is totally no sense to not have the app available only in Samsung TVs with Tyzen OS. Could you PLEASE review this issue?
The Web app team is working with Samsung now. There was a problem with the submission paperwork they sent to Samsung.
It is being corrected
Thanks !!!
I use Plex a lot and I was a bit sad when I did not find the application on the new TV.
´s
Still not available.
@dcbinder said:
It worked like a charm ! Thank you !
Are you confirming the app is now available in Brazil?
@ChuckPA on my tv did not show up at the store. :frowning:
@dcbinderr ???
@ChuckPA I tried it today at the Brazilian store and it is not available yet.
Any news about?
[]'s
Michel Marinho
Yes. The app is officially being vetted (tested) by the Brazilian app store team.
The worst is over at this point. :fingers_crossed:
Sorry Chuck, I´ve posted a reply to another discussion here. Unfortunatelly Plex app is still not available for Brazil. As a workaround Samsung Tyzen users can access Plex through the built-in Samsung web browser. It´s not easy to use as you have to navigate with a mouse pointer, but it works. Another option is to set the TV to another region like US, but on doing that we lose a lot of local apps, so, it´s not a good choice. I hope we can have PLEX app fully available on Samsung Store soon.
Thanks for your assistance.
Hello, Any news?
The answer is not accepted. We are still waiting for the app realeasing for Brazil !
I have done as much as I can.
Write to Plex directly through the web site is your next step.
Sorry, but what do you mean? As far as I know I am writing directly to Plex as I am always directed to this support forum to get technical support. Please, if there is another way of contact where I would be able to escalate this issue let me know.
Thanks in advance.
While it may direct you here, which is the correct first step, I’ve done all I can. I reached out to the product team and reported what they told me.
I have no new news.
Your only recourse is to go to www.plex.tv and use ‘Contact’ at the bottom of the page. That is the only way to escalate at this point.
I checked one more time. The update of February 7 was approved by Samsung. It should be available to you.
Please verify availability date of Feb 7. Advise with screenshot if what you see is different?
One of the Plex Dev’s just checked. It’s not listed.
Disregard my request. They see where it went sideways
Hi Chuck ! No problem at all ! I am available to check it any time you need.
Regards
I can tell you this and hope you see the humor.
The Dev loaded it manually. There is at least ONE television in Brazil with the app now. Does that count? :smiley:
Anyone feel ambitious?
From the Dev Team.
here’s a tidier side-load build of 3.3.2. Sharing this is fine so long as it carries the caveat that it’s a preview release. It won’t receive updates/bug fixes.
