All version latest app ans server both
Why the video is soo small.
Check the zoon value. Is it set to original? That means to play it at the original resolution without any scaling. So a 480p video will only use 480p of the screen.
This is a 1080 p video
Ya the screen set in original
And what is the resolution of the screen?
U mean the device i am using
Its 1080p display
Ok, that seems wrong. Can you post your Android logs?
Manufacturer: Xiaomi
Device: lime
Model: M2010J19SI
Product: lime_in
Version: 11
I still need the logs.
Where to find?
Android logs ← click that for instructions
Not seeing anything wrong. The app correctly sees the size of the file and the size of your screen. Are you sure the video just isn’t like that? Can you provide that file if it’s not too big or a sample? Upload to Google drive or similar and PM me a link.
Try changing the display mode to Letterbox.
Ya it works but the quality gets poor
Not only this but all the movies i uploaded is like that small
Here’s some more info on the settings.
I tried this file (movie) in my tv /mobile its working well but in plex its showing the problem
Are you streaming over the mobile network or on a remote network?
It looks like Plex is transcoding the video to a lower resolution.
Maybe due to a bandwidth restriction either on the server or the android app?
