Why transcode 1080 to 1080?
Hi :slight_smile: Why is that so ? Why my server transcode this ? Can we disable completely video transcoding ?
dea77d6da7e7f77bd71e5db3bbb41a936789dd52
Since you are using Android TV it will also say the general reason it is transcoding in the app in playback info. during playback bring up controls, in the menu on the right where you can select playback settings and such like change subtitles choose Playback Info
Yes it’s a remote stream… If the remote connection isn’t quick enough the server downgrade quality and transcode… i didn’t knew that but it’s obvious when we think about that. Thank you.
I tried disable transcode in advance mode. I’ll se if think change
It’s a remote connection but yes i’ll check that. Thank you
